Leicagoodies Shade
Stealth3kpl
It works for me. Before I added it to an M4-P there were times I could hardly see the focus rectangle. The shade fixed the problem. But that's only one case. What model would you put it on?
I didn't try it, but I use a small rectangular piece of 3M vinyl tape about quarter the surface of the window on my M6.
It sits in the middle of the window and dims the bright lines to a level, where I can still sufficiently read them.
It prevents complete white out sufficiently.
I plan, to have the finder upgraded at some point, but this little tape trick helps.
I do the same and haven't noticed any problem since adopting this technique. It would be nice if there were a neater solution though.
Pete
Pete
I am afraid, the only neater solution available costs 250,- upwards and includes opening up the top deck and doing some fiddle and an extra part or two ;-)
Worth every penny IMHO, it made my M6 a much more usable camera. I just couldn't deal with the white-outs after using an M8 and seeing how well its finder worked.
Used it before and it definitely works. The only problem is after a while the adhesive loses it stickiness and it dropped off my camera without me noticing. :rolleyes:
I never bothered getting another one. :D
