vented lens hood for Summicron 35 ASPH
skovbo13
Sorry about the huge picture. :)
I just discovered Heavystar on ebay myself. They seem to have a few options, any hood you would particularly recommend?
Yes - the vented sloped one. The straight one has a bit more viewfinder blockage.
I madfe my own from a standard hood, using a modelling drill and small file, inspired by the similar opening on the 21mm Elmarit asph hood, for which I can see no reason since you don't look through the camera viewfinder for it!
Gerry
The Leica 12504 looks good, and I prefer that it's snap-on.
Which size of caps does that one use?
Unfortunately there's a problem with that cap/hood combination on the ASPH lens. For storage the hood is intended to be reversed over a lens and the cap fits over the attachment lugs of the reversed hood. On the ASPH lens both the aperture adjustment ring and/or focus tab prevents you from reversing the hood. This applies to both the 12504 two part hood and the 12585 single part hood. The 12585 gives better flare protection than the 12504 hood. Both hoods when reversed take the 14033 cap but can't be reversed on the 35 ASPH Summicron. It may be possible to find another manufactures 52 - 53mm lens cap that will fit into the front of the 12585 or 58mm cap for the 12504.
The best flare protection for the ASPH lens is given by the 12526 rectangular hood with 14043 cap, the cap however doesn't have a particularly firm method of fixing.
Bob.
Gerry
There is a reason when you do look through the camera VF, for instance for a better checking of parallelism of horizontal and vertical lines then the one made possible through the external 21mm VF.
Thank you for the picture of your hood! I will try that as well!
Regards,
Manolo
The best flare protection for the ASPH lens is given by the 12526 rectangular hood with 14043 cap, the cap however doesn't have a particularly firm method of fixing..
Hi
The 15626, can be used on the pre asph lux as well. I've not noticed any vignetting on film Ms
If you want to see through the hood you will need to notch it, as.
I madfe my own from a standard hood, using a modelling drill and small file, inspired by the similar opening on the 21mm Elmarit asph hood...Gerry
It is however simpler keeping both eyes open.
If you want the cap to fit more tight, try holding it in front of boiling kettle spout and bowing it for a tighter fit.
The hood is not a problem on a 35 ASPH. Mine goes in my bag on the front of the lens all the time.
It takes a standard 39mm lens cap.
You must have smaller fingers than me :D. I can't get my fingers inside the unreversed hood to release the cap ...... unless I have a filter on the lens which moves the cap forward enough to get a purchase.
Bob.
Bob.
It may be the cap used has the release mechanisms on the front face, if you ping one side off with the lens facing down the cap will drop into open palm.
Noel
  • 2 weeks later...
I just received the 12585 hood I ordered and am quite underwhelmed with its fit on the 35/2 asph. I guess it's normal that it doesn't stay fixed and just spins around? Standard 52mm caps don't seem to fit the hood either.
Yes there is no stop pin preventing the hood to rotate contrary to the good (imo) 12526. Same for the 12504. Also the cap of the 12585 fits only when the latter is reversed, which can't be done with the 35/2.
