'Lens sound'?
vertekijker
At the risk of sounding ridiculous... I normally shoot with my M9 and the 28 asph. Cron, or 24 asph. Elmarit, or 35 Summarit. Today I decided to use for a change my old 28 asph. Elmarit which I bought when the M8 came out, but have used little since. As I took some pictures with it, I noticed that it sounded a bit louder than when I use my other lenses. As a piano player I am well aware of tonal changes in my piano, which is why I perhaps notice such little differences in sound. Is this possible? I imagine that because lenses are constructed differently, that some lenses allow for more generation of sound inside the camera than others do. As rear elements protrude farther inside or less, the sound chamber inside the camera is increased or decreased, it would appear. Or the construction inside the lens might be the cause of a louder sound because of it being more compact or containing a wider separation between lens elements.
Curious to get members' take on this.
Anyway, as a result of today's experience I'm switching back to my 28 cron and 35 summarit when I need to go unnoticed.
I look forward to your reactions.
Frans
Frans -
As you began to describe the situation I assumed the louder noise was as you speculate -- less isolation of the camera sounds by the older lenses. I've noticed differences with my current (R8) and past SLRs (Oly) with different lenses.
Frans
You arouse my curiosity (as a recorded music reviewer!). So I tried the fairly heavy 50 Summilux then the ultralight v4 35 Summicron, both at 1/125 in a quiet room after midnight (ie no external ambient noise), and the sounds are quite different: the greater mass damping the shutter sound, the v4 light and 'tinny'. So there you are......:)
All different Leica lenses I tried so far, sound different.
From the lenses, I own, the 50 Lux ASPH being the most muted sound with a rather soft and light click, the 90 Cron pre ASPH, being the most substantial in sound and click.
As I tried different copies of the same lens, before buying, I found differences between samples rather small on this one though.
I remember reading some time ago a claim of Ken Rockwell, that all Leica lenses do feel the same and how important is was for a lens manufacturer, to get the feel of manual lenses similar (focus, aperture) and can not understand this - they indeed feel very different.
Thanks for the confirmation, Microview. Glad I'm not alone in 'hearing things'... ;)
Frans
I have not tried different copies of the same lens yet. Amazing that even in that case small differences would exist. Thank you.
Frans
Happy to know you are a piano player, Frans !!! Here's how the the 21 Asph distorces a little the sound of my Hoffmann... :)
[ATTACH]205717[/ATTACH]
(see another thread about... ;)http://www.l-camera-forum.com/leica-forum/customer-forum/127014-35mm-distortion-2-a-2.html#post1345197)
Seriously speaking, me too notice the difference in sound when you have different lenses... I think it's related to the different masses which play surely a role in vibrations / sound absorbtion etc... ; probably, also the distance shutter - back lens element plays a role about perceived sound frequencies.
With "new" lenses, I feel it clearly, for instance, withSummicron 35 asph vs. Elmarit-M 90; with old lenses (and old M cameras too) a good example was Summaron 28 vs. Summarex 85... ;)
We should start a new game in the forum: "Hear the lens!"
Everybody can publish a sound file, the others have to find out which lens it is. Beginners just have to name the lens on a given body, advanced members have to guess the combination between lens and body.
Never given a thought to this.... Will try it this evening when it´s quiet here. Suppose one can tune the lens by turning the focussing ring (changes the enclosed air volume). Room for experiment. How about forming a Barnack Memorial Orchestra?
Just got a Luigi strap to replace the original one; wonder if I can hear that. too.....?
Just got a Luigi strap to replace the original one; wonder if I can hear that. too.....?[/quote]
By sure, they have a pair of large rings : room to attach a pair of little bells... :D
You play all the good stuff, I notice. I personally would add a little Bach as well. The 'Well-Tempered Klavier' is a daily favorite.
But on the topic at hand, I am glad that you have noticed the same phneomenon. You too 'resonate' with this topc, Luigi. ;)
Cheers!
Frans
I think it would be difficult, Uliwer, but I'm sure it can be done!
Glad you resonate as well with this topic, Per.
Frans
Cheers!
Frans
Vol. 1 and 2 of Wohltemperierte Klavier are regularly on the left side of the top... :)
FWIW--
"Sound design" is a growing technical field and business. There's a 4-minute video (German language) in the "Video des Tages" section at the bottom of the page at Start | Deutsche Welle.
Under the "Mehr Videos" tab, scroll down to "Der Sound des Staubsaugers." (Actually, despite the title, most of the clip concerns getting the right sound from bottled beer.)
Leica already designs lenses for small size and high optical quality. I wonder how much the price will have to rise when they start designing for sound as well. :(
FWIW--
Good question! You just gave them an idea...
Frans
Clearly we're due for a thread on how the acoustic response of different lenses affects image quality.
Me, I'm planning to market a range of clamp-on lens hoods and focus rings with built-in dampers and resonators so people can spend thousands fine-tuning their gear.
Later, there'll be models with piezo transducers and digital circuitry so we can argue over whether analogue or digital technology is best. :cool:
