erichuang Posted May 26, 2010 Share #1  Posted May 26, 2010 Advertisement (gone after registration) I just bought a 135mm version 2, I think it is a version 2 according to the design and it had a goggle adjustment done to fix the vertical alignment problem. It is made in Canada. I am trying to figure out what is the filter size for this lens and the sources are conflicting. I ended up buying a E55 because the barrel says "Canada 55" and the design looks very much like a version 2. My Leica E55 UV IR cut filter would not screw in and I hope someone could help me identify the right filter size. Please help if you have experience with this lens and/or know anything about it. Thank you all in advance. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/122063-help-elmarit-m-135mm28-filter-size/?do=findComment&comment=1334820'>More sharing options...
Advertisement Posted May 26, 2010 Posted May 26, 2010 Hi erichuang, Take a look here Help! Elmarit-M 135mm/2,8 Filter Size. I'm sure you'll find what you were looking for!
MAX Posted May 26, 2010 Share #2  Posted May 26, 2010 (edited) for earlier S-Numbers until 2.7xx.xxx you must use a Series-Filter Typ VII  a Link: Leica Filter Serie VII UV/IR Fass.schwarz - Rahn GmbH Foto & Fine Art  or look here: Leica | Series 7 UVA/IR Glass Filter (Black) | 13-421 | B&H  ( lt. LEICA Taschenbuch 7. Aufl. ) Edited May 26, 2010 by MBI Quote Link to post Share on other sites More sharing options...
erichuang Posted May 26, 2010 Author Share #3 Â Posted May 26, 2010 Thank you for the quick reply. I considered the Series Type VII as well, but saw that it doesn't look like it will fit and read that version 2 should be E55. I will most likely try the Series filter as that might be the only other option. Do you or anyone know if that filter will interfere with the built-in hood and front cap? Any other feedback is appreciated. Quote Link to post Share on other sites More sharing options...
Xmas Posted May 26, 2010 Share #4  Posted May 26, 2010 Hi  The series filter and the series ring are both low profile and do not interfere  You will need to get a ring as well as the filter - the ring has a five digit code and is available 2nd hand. Think you can get pola filters as well.  Noel Quote Link to post Share on other sites More sharing options...
luigi bertolotti Posted May 26, 2010 Share #5  Posted May 26, 2010 Hi The series filter and the series ring are both low profile and do not interfere  You will need to get a ring as well as the filter - the ring has a five digit code and is available 2nd hand. Think you can get pola filters as well.  Noel  Just to complete, the above ring has code 14161R (it was supplied with the lens, originally... easy to be lost). Easily available on ebay etc...  But, given that you already bought an E55,can be a pity not to use it... and there is an alternative : the thread mount on the Elmarit front is 54mm (it accomodates the 14161), and I think that an adapter ring to mount a E55 filter can be found somewhere (not in B+W catalog, but I seem to have seen something on ebay, from a quick search...) . I'm almost sure that an E55 mounted this way does not anyway interfere with the hood. Quote Link to post Share on other sites More sharing options...
Xmas Posted May 26, 2010 Share #6  Posted May 26, 2010 Just to complete, the above ring has code 14161R (it was supplied with the lens, originally... easy to be lost). Easily available on ebay etc... But, given that you already bought an E55,can be a pity not to use it... and there is an alternative : the thread mount on the Elmarit front is 54mm (it accomodates the 14161), and I think that an adapter ring to mount a E55 filter can be found somewhere (not in B+W catalog, but I seem to have seen something on ebay, from a quick search...) . I'm almost sure that an E55 mounted this way does not anyway interfere with the hood.  Hi  Luigi is correct you can get a step ring from series VII to 55mm, it should not interfere, if you use deep profile filters, e.g. a pola, they will reduce the travel of the cap on the hood, not a real problem, dont telescope the hood fully.  Noel Quote Link to post Share on other sites More sharing options...
erichuang Posted May 26, 2010 Author Share #7 Â Posted May 26, 2010 Advertisement (gone after registration) Thank you Luigi and Xmas for the great information. I am very happy to hear that there are alternatives and I do hate to not use the E55. I will look around for the Series VII to E55 adapter to see how well it works and hopefully it will save me trouble and keep the E55. Â Again, many thanks to all of you. Very greatful for such great forums. Quote Link to post Share on other sites More sharing options...
tobey bilek Posted May 27, 2010 Share #8 Â Posted May 27, 2010 The ser 7 retaing ring lives on my 135 and there is no interference. Â Third party one are bigger and will cause problems. Quote Link to post Share on other sites More sharing options...
swamiji Posted May 27, 2010 Share #9 Â Posted May 27, 2010 There are two versions of this edition of this lens, one for M the other for R. The series VII retaining ring is the same for both. I have the M lens with the R retaining ring, and it works perfectly. Â On a side note, I have both the Visoflex III and Bellows II adapters, a most versatile lens. Quote Link to post Share on other sites More sharing options...
erichuang Posted May 27, 2010 Author Share #10  Posted May 27, 2010 The ser 7 retaing ring lives on my 135 and there is no interference. Third party one are bigger and will cause problems.  Thank you for the information. I am getting a step up/down ring made by Heliopan. I hope that works fine. What kind of problems will I have if I used 3rd-party ones? Quote Link to post Share on other sites More sharing options...
luigi bertolotti Posted May 28, 2010 Share #11 Â Posted May 28, 2010 Thank you for the information. I am getting a step up/down ring made by Heliopan. I hope that works fine. What kind of problems will I have if I used 3rd-party ones? Â If it's this Heliopan code : Â 190 55 x 0,75 54 x 0,75 I think is right, and thinkYou'll have not problem with the hood. Quote Link to post Share on other sites More sharing options...
erichuang Posted May 28, 2010 Author Share #12 Â Posted May 28, 2010 If it's this Heliopan code :Â 190 55 x 0,75 54 x 0,75 I think is right, and thinkYou'll have not problem with the hood. Â Yes, that is the exact one I got. The description on Amazon is "Heliopan 190 Adapter 55/54 - Heliopan 700190". It should be here in a week or two at most. I will test it out and let everyone know how it went. Â Keep the feedback going if anyone has additional comments or information. I hope this thread is appropriate. Thanks! Quote Link to post Share on other sites More sharing options...
Xmas Posted May 29, 2010 Share #13 Â Posted May 29, 2010 Well mine (a type I) has a bad trait shooting into low sun, it does very well for a single coated lens when the sun is in frame, but can misbehave (flare) badly when just out of frame. Â If you are shooting into Fresnels or profiles, move about until you are familiar with the (your) lens. Â Noel Quote Link to post Share on other sites More sharing options...
erichuang Posted June 5, 2010 Author Share #14 Â Posted June 5, 2010 Thanks again for everyone who contributed to my scream for help. I kept the Lecia E55 UV/IR cut filter, bought a Heliopan 190 55 x 0,75 54 x 0,75 ring, and it arrived today. I attached the filter to the ring, put it on the lens, took two shots using f/2.8 and f/4.0 and both look clean with no problems. I am a happy man. Quote Link to post Share on other sites More sharing options...
George Stoichev Posted June 27, 2022 Share #15  Posted June 27, 2022 I found in eBay nice Elmarit M 135mm 2.8 but it doesn’t have filter. From all I read above I didn’t understand what is the filter I need for this lens? Quote Link to post Share on other sites More sharing options...
pedaes Posted June 27, 2022 Share #16  Posted June 27, 2022 43 minutes ago, George Stoichev said: I found in eBay nice Elmarit M 135mm 2.8 but it doesn’t have filter. From all I read above I didn’t understand what is the filter I need for this lens? As above - either Series VII, or if second version from #2,788,927 a E55. That said, Leica numbering is notoriously loose, so if you are around change point I would check carefully. Quote Link to post Share on other sites More sharing options...
a.noctilux Posted June 28, 2022 Share #17  Posted June 28, 2022 15 hours ago, George Stoichev said: I found in eBay nice Elmarit M 135mm 2.8 but it doesn’t have filter. From all I read above I didn’t understand what is the filter I need for this lens? I bet that the lens has retaining ring 14161 ( VII like this one ) attached. In this case use Series VII filters or with luck E49 filters. 1 Quote Link to post Share on other sites More sharing options...
George Stoichev Posted June 28, 2022 Share #18  Posted June 28, 2022 I requested the serial and it is 22899…. does it mean ring 14161? Quote Link to post Share on other sites More sharing options...
a.noctilux Posted June 28, 2022 Share #19  Posted June 28, 2022 2 hours ago, George Stoichev said: I requested the serial and it is 22899…. does it mean ring 14161? Ask the seller, 14161 ring has the marked "14161" and "VII". This ring can be tricky to unscrew, though, just grab ONLY one side to unscrew. Quote Link to post Share on other sites More sharing options...
luigi bertolotti Posted June 28, 2022 Share #20  Posted June 28, 2022 (edited) 3 hours ago, George Stoichev said: I requested the serial and it is 22899…. does it mean ring 14161? In case you want to use it regularly, consider that the last version (*) - new optical cell - is definitely better, at least for my experience. (*) finely knurled focus ring, single-cast goggle unit, single-piece hood, E55 Edited June 28, 2022 by luigi bertolotti Quote Link to post Share on other sites More sharing options...
