M bayonet extension tubes
brucek
  • Replies 43
  • Created
  • Last Reply
Of course, the goggled macro adapter for the current 90 Macro-Elmar is essentially a revival of the SOMKY, and thus incorporates an extension tube. IIRC only the 90 ME can be mounted on it, though (upside down).
Leica Camera AG - Photography - LEICA MACRO-ELMAR-M 90 mm f/4
Upside Down ? I don't think... how could it couple the RF ?
  • 3 weeks later...
I use rather a lot my SOMKY... and almost any "next to macro" pic of my gear that I posted here has been made with it : M8+SOMKY+UOORF+Summicron 50 head (without the UOORF ring you can mount only collapsible Elmars or Summicron)
[ATTACH]195132[/ATTACH]
Is a pleasant combo to use.
For which focal lengths does the above statement apply? 50 mm? 90 mm?
The SOMKY only works with 50mm lenses. AFAIK they are the Summitar, collapsible Summicron and original f/2.8 Elmar, plus the lens head of the rigid Summicron via the UOORF.
John,
Thanks.
So the 50mm f/2.8 Elmar (1957-1974) should work, right?
How about the 50mm f/2.8 Elmar (1994-2007)?
Are there other 50mm f/2.8 Elmar lenses?
I know there are older 50mm f/3.5 Elmars.
K-H.
John,
Thanks.
There are only the two f/2.8 Elmars. I don't know for sure that the later one won't fit the SOMKY, but both the optics and the mount are different from the original and I've never heard of anyone doing it.
Maybe I've interpreted badly "upside-down" as "front lens towards the body"... you mean 180° rotated on its axis ?
Yes. Upside down as in rotated, not backwards.
There is a second focal scale on the bottom of the lens that is exposed when mounted on the adapter. Presumably the focusing cam must have two different spots that the wheel hits.
  • 2 weeks later...
Please Luigi how difficult is to separate the optical part of the one rigid 50mm Summicron ( sn 2268000-2995000 aprox. ) in order to be connected to UOORF unit .I am interested also in to complete my BOOWU M with M8.2.
thanks
Anyway, here is my "new" SOMKY mounted on the M9 with the Elmar 3.5/3.5, and a shot with the combo (uncropped, closest distance)
