jaapv Posted March 29, 2010 Share #101 Posted March 29, 2010 Advertisement (gone after registration) I can confirm that, E2 works fine, Wilson. For travel, I just put it in the checked luggage in my toiletries bag. It is impossible to pick it up on X-ray and differentiate it from aftershave or eyedrops. Link to post Share on other sites More sharing options...
Advertisement Posted March 29, 2010 Posted March 29, 2010 Hi jaapv, Take a look here M9 Ultimate Sensor Cleaning Device . I'm sure you'll find what you were looking for!
Baptiste Posted March 29, 2010 Share #102 Posted March 29, 2010 But dudes, didn't you have remaining dust on your sensor? I did, that's why I ask Link to post Share on other sites More sharing options...
RoRoRoPa Posted March 29, 2010 Share #103 Posted March 29, 2010 Has anyone tried one of the new Visible Dust Zeeion ionizing blowers? Effective tool or silly over-priced gimmick? Wilson Check out the blower challenge: Link to post Share on other sites More sharing options...
wlaidlaw Posted March 29, 2010 Share #104 Posted March 29, 2010 Check out the blower challenge: Thanks I found that too. Zeeion looks like a bust and may be risky for the electronics as well. If I still am occasionally not having good enough results from the Arctic Butterfly (used after wet clean as well as before - Baptiste please note), I will get my daughter to bring me across a Firefly when she comes over from the USA in August. Wilson Link to post Share on other sites More sharing options...
k-hawinkler Posted March 29, 2010 Share #105 Posted March 29, 2010 Wilson, Would you consider SensorVu? That seems to help me most - in addition to a wet cleaning with E2. K-H. Link to post Share on other sites More sharing options...
MaxFoto Posted March 29, 2010 Share #106 Posted March 29, 2010 Hi folks, spent most of last Sunday with the M9 sensor cleaning stuff. There was 1 significant spot at f/16 and some small ones around. Thinking this must be more perfect I started equipped with Eclipse, Swabs and an orange sticky device. I got less and less nervous the more I had to repeat the procedures. No fear the sensor is robust. This is the good news the M9 sensor is good accessible. The bad news is to get that f... thing clean. At the beginning it got much more worse than from what I started. Stopping, shipping to anywhere,... no way I have to do it! So one more time wet cleaning followed by picking around with the sticky thing. No problems with the swabs, they remove the dots but leave other dust or whatever. Finally I ended up with a semiclean sensor there is again one spot left. Swabs alone you can forget it. Best turned out the combination of swabs and Pentax Sensor Cleaning kit. So what is best sensor cleaning method? KR, Wolfgang Link to post Share on other sites More sharing options...
k-hawinkler Posted March 29, 2010 Share #107 Posted March 29, 2010 Advertisement (gone after registration) Hi folks, spent most of last Sunday with the M9 sensor cleaning stuff. There was 1 significant spot at f/16 and some small ones around. Thinking this must be more perfect I started equipped with Eclipse, Swabs and an orange sticky device. I got less and less nervous the more I had to repeat the procedures. No fear the sensor is robust. This is the good news the M9 sensor is good accessible. The bad news is to get that f... thing clean. At the beginning it got much more worse than from what I started. Stopping, shipping to anywhere,... no way I have to do it! So one more time wet cleaning followed by picking around with the sticky thing. No problems with the swabs, they remove the dots but leave other dust or whatever. Finally I ended up with a semiclean sensor there is again one spot left. Swabs alone you can forget it. Best turned out the combination of swabs and Pentax Sensor Cleaning kit. So what is best sensor cleaning method? KR, Wolfgang Wolfgang, That's my experience as well. The SensorVu sticky seems to be the same as the Pentax Sensor Cleaning orange sticky device. I started out with wet cleaning, pushed pretty hard and got a lot of additional stuff on the sensor in the area where I lifted off the swab. I am not sure, but I have the feeling that may be fibers from the swab are being left behind as this stuff looks really different from the dust on the sensor. Luckily, I could get the stuff I had deposited on the sensor with the wet cleaning off with the orange sticky. Cheers, K-H. Link to post Share on other sites More sharing options...
jaapv Posted March 29, 2010 Share #108 Posted March 29, 2010 But dudes, didn't you have remaining dust on your sensor? I did, that's why I ask Well, I had to use this surgical microscope to get everything off.... Link to post Share on other sites More sharing options...
Guest Chris M Posted March 29, 2010 Share #109 Posted March 29, 2010 Well, I had to use this surgical microscope to get everything off.... Hi jaapv, yes just curious though? did you notice a difference in final output or on your monitor before and after a microscopic cleaning. I'm just wondering because I don't have a microscope to clean with and really can't tell before or after a cleaning on my M8"s files viewed from a new 24' apple monitor or my final 16x20 prints. chris m Link to post Share on other sites More sharing options...
ryanpeck Posted March 29, 2010 Share #110 Posted March 29, 2010 Really interesting post all around. Thanks. I was cleaning a couple of LPs today and it occurred to me that the bits of lint and fluff that stick to them is very similar to the problem we all face with our sensors. On my records, I use a fantastic tool called a ZeroStat Gun. It removes the static electricity from the surface of the record and, voila, i can usually just blow away the particles that wouldn't budge before hand. Might be an interesting device to incorporate into the microscope test... Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/111757-m9-ultimate-sensor-cleaning-device/?do=findComment&comment=1277072'>More sharing options...
wlaidlaw Posted March 29, 2010 Share #111 Posted March 29, 2010 Wilson, Would you consider SensorVu? That seems to help me most - in addition to a wet cleaning with E2. K-H. K-H, I am very reluctant to use any sticky device after a Dust Aid came in half as I was peeling it off its backing paper. I can just see the sticky bit sticking on to the sensor and coming off the wand = goodbye shutter. Wilson Link to post Share on other sites More sharing options...
scc Posted March 29, 2010 Share #112 Posted March 29, 2010 I don't have a microscope to clean with and really can't tell before or after a cleaning on my M8"s files viewed from a new 24' apple monitor or my final 16x20 prints. chris m Perhaps your sensor wasn't that dirty before you cleaned it? I hear what you're saying though. I have access to a microscope, but haven't yet needed to use it for a clean. Using a sensor loupe for guidance, and following a clean with VD swabs and fluid, I cannot notice any artifacts in my pictures. Anything that doesn't show up in pictures isn't worth chasing, ultimately. However, I definitely do notice a difference before and after cleaning - the spots in my pictures disappear! S Link to post Share on other sites More sharing options...
wlaidlaw Posted March 29, 2010 Share #113 Posted March 29, 2010 Really interesting post all around. Thanks. I was cleaning a couple of LPs today and it occurred to me that the bits of lint and fluff that stick to them is very similar to the problem we all face with our sensors. On my records, I use a fantastic tool called a ZeroStat Gun. It removes the static electricity from the surface of the record and, voila, i can usually just blow away the particles that wouldn't budge before hand. Might be an interesting device to incorporate into the microscope test... I remember using those on LP's about 30 years ago. However, do you really want to go firing electrostatic charges into a device full of sensitive chips? I assume you were not being serious. Wilson Link to post Share on other sites More sharing options...
swamiji Posted March 29, 2010 Share #114 Posted March 29, 2010 I remember using those on LP's about 30 years ago. However, do you really want to go firing electrostatic charges into a device full of sensitive chips? I assume you were not being serious. Wilson I have one of those... unregulated, extreme voltage... Not near my M9.... The thought is too scary to entertain.... I second Wilson's view. Link to post Share on other sites More sharing options...
k-hawinkler Posted March 29, 2010 Share #115 Posted March 29, 2010 K-H, I am very reluctant to use any sticky device after a Dust Aid came in half as I was peeling it off its backing paper. I can just see the sticky bit sticking on to the sensor and coming off the wand = goodbye shutter. Wilson Wilson, I hear you. Well, I have both the Dust Aid and the orange sticky. They are of a completely different design. The orange sticky is just a blob on a stick. Unless the blob itself disintegrates it's hard to see how a bit can be sticking to the sensor. I certainly don't plan on using the Dust Aid again as it didn't seem to work very well for me in comparison. K-H. Link to post Share on other sites More sharing options...
jaapv Posted March 29, 2010 Share #116 Posted March 29, 2010 Hi jaapv, yes just curious though? did you notice a difference in final output or on your monitor before and after a microscopic cleaning. I'm just wondering because I don't have a microscope to clean with and really can't tell before or after a cleaning on my M8"s files viewed from a new 24' apple monitor or my final 16x20 prints. chris m I did see some remaining dust with f16. As I usually don't close down beyond 5.6 it was of no practical relevance. It was more of an perfectionist excercise. But it turned out to be so easy and practical that it will be routine in the future. Link to post Share on other sites More sharing options...
Baptiste Posted March 29, 2010 Share #117 Posted March 29, 2010 Wilson, I hear you. Well, I have both the Dust Aid and the orange sticky. They are of a completely different design. The orange sticky is just a blob on a stick. Unless the blob itself disintegrates it's hard to see how a bit can be sticking to the sensor. I certainly don't plan on using the Dust Aid again as it didn't seem to work very well for me in comparison. K-H. I viewed a youTube video of that orange stick use. It frightened me to see someone pushing obviously so hard on the sensor. Someone reported that the M9 sensor is tough enough. But with these broken glass issues reported on the forum, I doubt it (even if the 2 things could be not correlated) Link to post Share on other sites More sharing options...
MikeMyers Posted April 1, 2010 Share #118 Posted April 1, 2010 I've been helping some friends of mine in India, who want to record eye operations using a camera on the microscope. Most of these cameras have a "video out" connector. I got a device from Pinnacle, which converts the analog video signal to digital, and by means of a USB connection allows a person to record the video on a computer in any format they want, up to high-res AVI. I think it would be fascinating to try to create a video of what's going on during the cleaning operation, using the microscope both for the person to see what he's doing, and to record the person sees, so we can all see it on a website. If anyone wants, look up "Pinnacle Studio 12 with hardware" in google, and you'll see the device and the software they provide. It's extremely easy to use. It will only work though on a microscope with a camera attached. Link to post Share on other sites More sharing options...
Guido Posted April 1, 2010 Share #119 Posted April 1, 2010 I've succeeded today in removing half a dozen particles from my sensor with the help of a SpeckGrabber, a pad soaked with Isopropyl alcohol to clean the SpeckGrabber between passes, and an illuminated Visible Dust 7x loupe. I forced myself to only care about the larger artifacts which were readily visible in the f22 test, but from what I've seen with the VD loupe, I can well imagine that finding every subatomic dust bunny on the sensor with a real operating microscope would drive me nuts! Link to post Share on other sites More sharing options...
