R8 ..to repair or not to repair?
leicamann
Two days ago I was testing my SF20 flash unit on my R8, as per usual..I had a roll of film in the camera, but not wound all the way to the spool.......this time..however the remaining "tongue" of film tripped into the shutter and slashed the tops of some of the shutter blades and pushed out the lower one. Its obvious the shutter will have to be completely replaced.
So:
1) is it worth repairing?
2) what about the "Leica USA" horror stories I am reading on Photonet?
3)My guess is the repair cost will outstrip the actual worth of the camera
4) use for "spare parts"...forget it you just destroyed a perfectly good camera!!
5) sort of off topic, but many DMR users have been"damaging their shutter"..why?
Thanks in advance
Cheers, JRM
Photo.net is a hive of short-fused emotional fear-mongers.
that's what the seller assumed when I bought my backup DMR, he included an R8 with a damaged shutter. I popped the errant shutter blades back into place using a partly-straightened paper clip and a thumb.
I've heard more about film leaders damaging the shutter than I have about DMR-associated damage.
Doug..aaaaaaaaaaaaaaa..this is way more damage than a simple paper clip solution..have a look
Ouch! I know the sound of that happening.
Following a Kindermann recommendation passed on here I asked for a shutter repair quote and was advised:
Cost of shutter assembly, $300.00 Canadian dollar, labor to
Install approx. $325.00 Canadian.Of course subject to inspection
Of your Leica R8.
Rick, as painful it is to look at, its better for people to see and know..right?
The Kinderman quote sounds perfectly reasonable, I was getting figures of $1200.00 upwards..because it has the name "Leica" on it.
Cheers, JRM
Thanks. I've decided that if it falls within that price range..then I will get it repaired..its such a lovely camera...and I guess.."I won't be doing that again" :confused:
Thanks for your input
Cheers, JRM
  • 5 months later...
I have 3 R8's. I have never paid more than 600 for each. All are perfect & have been inspected by Leica in NJ.
Hi Ben, saw that you have 3 R8's I was thinking on getting one to go along with my m9
since I miss shooting with a reflex for telephoto's and close-ups.
I take it your happy with them.
Hank
