Showing results for tags 'sf c1'.
  • Forenumzug
    • Systemkamera Forum
    • Fuji X Forum (deutsch)
    • Fuji X Forum (English)
    • SAD Temp
    • CER Temp
Found 3 results
  1. Hello all, I wonder if anyone can shed some light on how to pair the C1 on-camera trigger with the SF40 flash, which I wish to use off-camera. I can find information online about connecting the trigger with the SF60 but there seems to be a lack of information on the same for the SF40. My first post here - new Leica user!
  2. I can't get the SL2 to fire in High Speed Sync with the SF60 flash in manual. It only works in TTL for High Sync. The High Speed symbol lights up in manual when you go past 1/250 but the flash doesn't fire. Has anyone gotten it to work in manual? Thanks
  3. I own a m10 and a SL. The latter is used with both SL and M lenses. I picked up a SF 60 used and have enjoyed it. I would like to experience TTL with off-camera strobes, so I am considering the C1, but have questions: 1) will it provide TTL sync for both cameras, even the SL+M lenses? 2) Will the Nissin Air 10s controller do the job at half the price as the Leica C1? 3) Which Nissin strobes have you triggered successfully with the C1 (as fill or secondary strobes)? Thanks in advance!
