Showing results for tags 'sf 60'.
I can't get the SL2 to fire in High Speed Sync with the SF60 flash in manual. It only works in TTL for High Sync. The High Speed symbol lights up in manual when you go past 1/250 but the flash doesn't fire. Has anyone gotten it to work in manual? Thanks
Maybe someone can help. on a few shoots not the Flash in TTL or A does not fire. Looks like this happens when the background in lighter . but in many case I place subject in the same and want to add some lighting the front. Does anybody has a solution? I have been using TTL to be able to shoot at higher exposures. this has been happening all the time, the flash didn't ever fire, it is not overheated.
