Showing results for tags 'sensor cleaning'.
So most of the photos from my last batch came up looking really weird. Here's a picture agains the sky where you can see what I mean: I don't think it is the lens, since I don't see the same problem with my m8.2. I live in Mexico City, so taking it to a Leica store to the US would be really expensive. I also don't really trust general camera stores here, the reviews I've looked at seem pretty bad. Has anyone had this problem as well? Should I try cleaning the sensor myself? Suggestions? Help!
Hello, you helpful lot. I hope. Found that I had a big bit of gunk on the sensor of my 8 year old M262 - it showed up on the photos. So I've taken my trusty blower brush to the sensor. There are still a few spots (see image) that I can't budge. They don't seem to show up. Is this a clean enough sensor in your experiences ? Is your sensor showing dust like this or is it pristine ? If you think I should get rid of the dust showing - how would I do that beyond the blower brush ? Thank you as ever for your collective help. In the past Leica colleagues have been magnificent in their help. Best Regard to all 262ers and all others of course.
- 9 replies
- sensor
- dust sensor cleaning
(and 1 more)
Tagged with:
I have noticed in the two more recent outings with my M240 that i have a lot of dust on my sensor. The attached image is from the most recent outing to see the airshow. The circles are the spot removal I had to do to fix all the dust. As you can see it is substantial. Note that I was stopped down to F22 on a 90mm lens to get the depth needed for the air crafts and people to be in focus. So the dust was more apparent in the image. I have cleaned the sensor with the blower multiple times. I have cleaned the sensor with swab and solution once between the outings. I switch lenses often enough for dust to get in, I expect it to happen. My problem is that after cleaning the sensor so thoroughly I should not have this much dust. It appears that using the blower provides minimal help and the swab basically nothing. Has anyone experienced such persistent dust? Could this be some sort of corrosion on the sensor? I am debating sending it in for a repair and service to fix the issue. Has anyone used this service before and has an idea of cost, procedure, and effectiveness in getting a clean sensor back?
- 14 replies
- m240
- sensor cleaning
(and 1 more)
Tagged with:
When I use the Sensor Cleaning > Dust Detection feature in my M10 Monochrom or M10-R, and see dust spots, I wonder if that image is reversed. The reason it matters is that when I then use the Open Shutter menu option to use a blower to clean the sensor, I want to direct the stream of air as directly as possible at the location where the spot is. So if I look at the image on the LCD from Dust Detection and see a spot in the upper right of the image, should I then direct the stream of air at the upper left of the sensor as I hold the camera facing me? (If that's correct, then the image is not reversed; the location of the spot is on the other side simply because I've rotated the camera body 180 degrees.)
Hi all, Hope everyone is getting on OK through the lockdown. I use the S-system for work (I'm just a basic freelance photographer), and thus far I've always passed off my bodies to Leica Service here in Ginza, Tokyo to clean the sensors. With the Leica reputation in connection to sensor cover glass, I have not taken any chances. Leica Ginza usually do the job for nothing (quick clean)---anything more involved that'd require a service charge can be written down on my expenses, so I do that and save myself the hassle. All good. {It's also better for me to put the liability more squarely on them, just in-case any sensor cover glass problems did arise: I do not want to eat the Leica after-service tax infamous in these parts---I'm only half joking.} However! Leica Ginza has been effectively shut down since 8th April and doesn't look like going back to normal service anytime soon. My sensors really need a clean, so I'll have to take matters into my own hands. Not scared about it, but I want to get this right in the least number of iterations. Please lend me your expertise m(. .)m I have just tried the Pentax O-ICK1 on my backup S2-P body today. The O-ICK1 (great name) is a kind of dry-clean implement, for anyone unfamiliar. Didn't go well. I had more dust on the sensor after cleaning than before! (I held myself back from doubling down and trying again) So it looks as though that was ¥3,000 down the tubes. No great shakes, but I'm looking for a different and better way now... I'm in Japan so many of the products available to guys in the West, that turn up on Google searches of this topic, don't seem to be available for me here. I checked older threads and saw a Visible Dust swab made for 30mm sensors (dunno if specifically for the 30x45 Leica Pro Format, but anyway...) which I can't get my hands on in Japan. So I'm looking for workarounds. I've never wet cleaned a sensor myself before, so please forgive my ignorance and beginner questions: 1) Can I just use a full-frame swab? Does the edge of a swab leave a line? Assuming yes, otherwise there would be no market for different sensor size swabs.. or is it all FUD (Fear, Uncertainty, Doubt) from the sensor cleaning-industrial complex? 2) Can I just wrap a lens cleaning paper on a bit of stiff card or plastic, some isopropyl alcohol on the thin edge, and DIY myself a swab? The one remaining dry-clean solution (that I know of) I haven't tried is a sensor brush, like one of those Arctic Butterfly brushes---how do we feel about those? That specific product is not readily available here, although there seem to be copycat brush products (which surely perform just as well). What is the main thing I am looking for in a sensor brush? (materials, size, etc) I can't say whether the majority of the spots on my sensors are dust or oil, etc., but blowing is not doing the trick so I definitely need to do something more proactive to deal with whatever it is. My two camera bodies are the S typ006 and S2-P, both have had new sensors in them to replace defective gen1 versions, so the cover glass on there is whatever spec the replacement CCDs come with. Any advice and experience welcome. Cheers. Tom
How often do folks typically need to wet clean their SL sensors? Lately my SL is picking up quite a bit of dust, and I seem to need to clean about once every 8 weeks or so, and I am not in a particularly dusty environment when I change lenses.
- 4 replies
- sensor
- sensor cleaning
(and 1 more)
Tagged with:
