Showing results for tags 'canon ef'.
Found 3 results
  1. Hi all! I have been testing the Commlite CM-EF-L autofocus adapter with several Canon EF lenses on my Leica CL, and I am glad to report that it works. As expected, AF-C and focus tracking is not supported, but the AF-S works reasonably well. Focusing speed and precision with most lenses is at almost native T/TL lenses level. So: -AF-S works (no tracking). Touch AF also works. -IS with Canon stabilized lenses works. -EXIF data is transferred correctly to the files, save for the F/1.2 that is reported as F/1.3 (something I had already seen with other third party AF adapters on Sony cameras). I used A and M modes, on Firmware 4.0. Adapter firmware is upgradeable via an USB port on the adapter itself. There are no new FW listed on Commlite’s site, and it worked right out of the box. The lenses that I tested, and worked, so far are: 14/2.8L-II, 16-35/4L-IS, 24/2.8 IS, 24/1.4L-II, 40/2.8 STM, 50/1.2L, 50/2.5 compact macro (with and without the Lifesize 1:1 converter), 85/1.2L-II and 100/2 USM. The only glitch I have experienced is that Battery level is not correctly reported to the camera, and the first time I mounted the adapter on the CL, I got a warning message about the “Camera possibly not displaying reliable battery charge levels with this lens” that did not repeat. In fact, after a hundred exposures with different lenses, the battery appeared as depleted. The workaround I found was shutting down the camera, taking off the battery, mount a native TL lens, put again the battery in and the charge was there again, correctly reported at about 2 / 3. During next week I will try to test the adapter with more Canon FF lenses, and EF-S APSc lenses. I am very interested to see how the compact EF-S 10/18 zoom and EF-S pancake 24/2.8 perform on the CL. So, after all the let down expectatives we CL users held on the MC-21 adapter by Sigma, I am glad to share that there’s still a light on the path to use many more lenses options!
  2. Great cheap ($18) adapter with two major caveats... First: this is manual focus only. Second: you must shoot with wide open aperture After saving many hundreds of dollars by NOT buying the German lens adapter, this is a great find! Most Canon EF lenses are very good wide open. The manual focusing on my Leica SL is perfection. Using my Canon 85mm f1.8 for portraits on the SL is a real improvement over using it on my Canon R mirrorless. Sure, the Leica Summicron SL 90 would be better but it is many thousands of dollars! If you have a TL format camera (Leica, Sigma, Panasonic) and Canon lenses — buy this! On eBay search for EOS-L/T Adapter For Canon EOS EF Lens To Leica LT/SL Type 701 Mirrorless Camera
  3. Liebe Mitforenten, ich plane den Kauf einer SL2-S und möchte hauptsächlich meine M- und R-Objektive benutzen. Kein Problem, dafür gibt es gute Lösungen. Aus meiner Canon-EOS-Zeit habe ich noch einige interessante Objektive, die es so nicht woanders gibt: EF Tilt-Shift 24; EF 50/1,2 und 85/1,2 und das EF 100 Macro IS..... Soweit ich sehe, gibt es zunächst den Sigma MC21 Adapter, wobei die Firma die Benutzung ausdrücklich für die Sigma-Gehäuse beschreibt und andere Fabrikate ausschließt. Ausserdem bietet Viltrox einen Adapter an, zu dem aber nirgends etwas zu finden ist. Gibt es bei den LUF-Lesern konkrete Erfahrung mit einem der beiden Fabrikate ? Funktioniert der Sigma-Adapter mit der SL2-S ? Vielen Dank für eine hilfreiche Antwort !
Ă—
Ă—
