Showing results for tags 'adapted lenses'.
    • Leica Q / Leica Q2
    • Leica FOTOS App
    • LHSA Member Forum
    • Leica FOTOS App
Name
PLZ
Found 2 results
  1. Hi all! I have been testing the Commlite CM-EF-L autofocus adapter with several Canon EF lenses on my Leica CL, and I am glad to report that it works. As expected, AF-C and focus tracking is not supported, but the AF-S works reasonably well. Focusing speed and precision with most lenses is at almost native T/TL lenses level. So: -AF-S works (no tracking). Touch AF also works. -IS with Canon stabilized lenses works. -EXIF data is transferred correctly to the files, save for the F/1.2 that is reported as F/1.3 (something I had already seen with other third party AF adapters on Sony cameras). I used A and M modes, on Firmware 4.0. Adapter firmware is upgradeable via an USB port on the adapter itself. There are no new FW listed on Commlite’s site, and it worked right out of the box. The lenses that I tested, and worked, so far are: 14/2.8L-II, 16-35/4L-IS, 24/2.8 IS, 24/1.4L-II, 40/2.8 STM, 50/1.2L, 50/2.5 compact macro (with and without the Lifesize 1:1 converter), 85/1.2L-II and 100/2 USM. The only glitch I have experienced is that Battery level is not correctly reported to the camera, and the first time I mounted the adapter on the CL, I got a warning message about the “Camera possibly not displaying reliable battery charge levels with this lens” that did not repeat. In fact, after a hundred exposures with different lenses, the battery appeared as depleted. The workaround I found was shutting down the camera, taking off the battery, mount a native TL lens, put again the battery in and the charge was there again, correctly reported at about 2 / 3. During next week I will try to test the adapter with more Canon FF lenses, and EF-S APSc lenses. I am very interested to see how the compact EF-S 10/18 zoom and EF-S pancake 24/2.8 perform on the CL. So, after all the let down expectatives we CL users held on the MC-21 adapter by Sigma, I am glad to share that there’s still a light on the path to use many more lenses options!
  2. For Using Leica's Historical line of Manual Focus Leica-M Lenses are the Leica SL, SL2, AND Nikon Z6, Z7, Bodies Essentially Equivalents? Same Ease Of Use? Same Easy focusing? Ease of Carry?
