IR cut filter and reflections
l.ceva
Here are two pictures taken with M8 and 28 SUMMICRON, the first one has the IR cut filter (LEICA) the second one is with out filter.
I read a 3D reporting no problems with reflections but I am not surprised about my results!!
ciao
Lorenzo
LORENZO CEVA VALLA - fotografia digitale
Lorenzo--
Good test, and as you said, the results are unfortunately not surprising.
Erwin Puts made the same discovery and wrote it up at Testreports.
It begins to look as if we now have one more decision to make before making each exposure: use the IR cut filter or not. :(
--HC
It is an old piece of advice to remove the filter in heavily backlit situations, or with strong light sources in the picture. This is as true with common UVa filters as with the UV-IR type. After all, coating does not suppress reflections completely. The only way to do that is a front cap ...
The old man from the Age Before Coating
Sir, how is it that some black colors look magenta on my pics?
- Perfectly normal dude. There is not such thing as perfect black. Magenta is a kind of black not-so-black black sort of, everybody knows this.
OK Sir, but how is it that we have to use IR-cut filters then if this is perfectly normal?
- Perfectly normal mate. Any self-respected Leicaphile used to use protective UV filters in the old days didn't they? Now they simply have to use UV-IR's instead to protect their little gems from dangerous radiations called Infra-Red (ouch).
But Sir, how is it that when i use those filters i get reflections, ghost images and that sort of things?
- Perfectly normal folk. Leica has always taught us that filters are unnecessary... except when they are necessary of course. Now filters are simply more necessary than before that's all. Suffice it to remove the filters when there are more bright lights than magenta blacks to shoot at. Simple no?
Got it Sir!
Perfectly normal Sir!
LCT, That was wonderful! I will write it down and carry this with me. Then before I take a photo I will check to see if it is necessary to remove the filter. Or not.
What does Leica recommend I do to keep the filter clean and dust free while it is removed, and should I explain these instructions to the subjects of the photo when I ask them to remain at their task, and look relaxed and natural while I determine whether the photo requires a filter or not, and then make the necessary changes to my lens?
Right, this is an old problem that is not directly related to the M8, IR-cut filters, etc. Even the best multi-coated filter can show reflections, etc. under exactly the wrong conditions - usually bright light sources against darker backgrounds. Under those circumstances, I think one is best off removing the filter and (if the pictures are color) using Jamie's profiles or the like if needed to correct for the IR color casts.
Cheers,
Sean
I take your point but many of us wouldn't be using a filter at all if it wasn't for the IR sensitivity of the M8. I've had IR/UV filters since around Christmas and have been inclined to think that the filters are a non-issue. However, I am beginning to see the odd image creeping in where the filters have introduced some problematic reflections and/or flare and am now considering taking the filters off. What I don't want to get into is a situation where I am constantly thinking whether I should leave the damn things on or off!
Those filters are perfect to draw subjects' attention to the photog at least.
What? I said it already?
Oops sorry...
I dunno- if your avatar is a self portrait that might be the problem.:p
For those who are dead against using the IR filter except for shooting subjects in black materials, what about the issue regarding IR light causing a slight drop in focus? Recall the good old days of shooting IR photos?
Do you guys notice that in incandescent lighting, without the filter, images are not as sharp without the filter?
That's true. Some people use protective filters as a rule of thumb but I'm among the group that tends not to use filters at all (unless I must). I do much of my work in B&W, where I use no filter on the M8 lenses. For M8 color work that involves bright lights in the frame, my recommendation has been to pull the filters and use the Jamie profiles if needed. I haven't yet had a filter-related problem with subjects lit by sun, it's more the night subjects that can sometimes pose problems.
That said, its important to clarify that this is a general problem with even the best filters and is not specific to the 486 filters, etc.
Like most, I'd rather not have to deal with the filters but I like the M8 so much that I do what I must to work with it.
Cheers,
Sean
Guest sirvine
I really don't get it...if you don't like using filters and you shoot color, don't use an M8. Unless you feel cheated because you pre-ordered back before Leica acknowleged the IR sensitivity, you really have nothing to complain about. It's called 'informed consent'. It's one thing to be a demanding customer, but something entirely different to mock a manufacturer with this tone of entitlement to absolute perfection. News flash: $5000 is not the price of perfection. Sorry about that.
Thankyou for your advice about the price of perfection!!
I have so meny complains that I brought an M8 with 5 brand new lens and I am going to buy another M8!
ciao
Lorenzo
http://www.lorenzocevavalla.it
Guest sirvine
Lorenzo,
I wasn't really aiming my comment at you, by the way. Your test is actually very fair. It was all the snide griping further down that gets on my nerves. I'll go have a coffee and get on with my life....too short to be negative!
Lorenzo,
Totally agee with you!! unfortunately there are so many possible reasons to be negative just a bit more important than this forum!!!
I understood that your message was not for me but I answerd only because as I opened this 3D I felt a bit "responsible".
My intent was not to comaplain but just to show what can happen in some particoular cases and as I said I did not expect a different behavior.
ciao
Lorenzo
