Leica 35 Summicron V2 Problem ?
Dan95
Yes, it seems, somebody has been fiddeling with it and didn´t manage
to put it together properly.
If bought from a dealer, convince him to send it to LEICA
for correction. In case it works o. k. and you can live with it use it.
In case it would be mine it would go to CS ...
best
GEORG
Not so uncommon on some old lenses... nothing bad if globally all the apertures are fine: it can be both an "original" situation (expecially in the very first batches of some "new - new version" lenses of those times), or the consequence of a CLA with disassembly of the lens. I have a very first Summilux 35 and a Summarit 1,5 with such little mispositioning... and keep them as they are...
I think that the biggest problem is that the lens is completely misengraved! ;)
If I remember, the version 2 'cron 35 has a retainig / tightening ring inside the rear lens mount. Check if this is not the issue - sometimes the ring can be loosened, lens unit re-positioned and ring re-tightened.
Best,
Jan
Actually, that is a normal modification for the version 2 lens.
The reason is the semaphore "tab" or lever used to operate the skinny aperture ring. It overlaps and interferes with the focusing tab near infinity if the aperture is properly centered and the lens is set to f/2. So the aperture ring and index are canted out of the way in some units (not sure if this was a change introduced during the factory run, or an after-market modification commissioned by frustrated photojournalists).
I'm looking at the illustration for this lens in Dennis Laney's Leica Collectors Guide - it is identical to the OP's lens - the aperture index mark is out past the f/16 DoF mark, towards the left (viewfinder) side.
Here's a snap of the v.2 with centered aperture ring, and you can see that its tab gets very close to the focus tab even at f/5.6 - easy to nudge the tab and bollux your exposure when focusing under pressure.
http://www.kenrockwell.com/leica/images/35mm-f2-1970/D3S_4243-1200.jpg
Within 4 years, Leica redesigned the mount for the third version, to get rid of the aperture tab altogether.
Yes totally normal folks.
>> ltc
thx for this !!
I had this lens - made in CANADA - bought in 1968. But I don´t recall, it was
aligned like this. If it was, I´am quite sure I would remember.
The lens is gone, it fell into Lake Mulungushi, then (almost) still Northern Rhodesia.
A long, long time ago.
Best
GEORG
...I don´t recall, it was aligned like this...
Hi Georg. The Summicron 35/2 # 11309 has been made in two different types, with and without aperture tab, if i'm not mistaken. Perhaps yours looked like this one?
Iirc, the optical cell could be loosened quite simply by the user by unscrewing the slotted ring around the rear element barrel. It could then be tightened with the index in any position without any impact on focussing.
>> ltc
Well , the one I lost looked pretty much like the first one, with tab. The
replacement looked exactly like #2, no tab, both where from Canada.
Never liked to be without a SUMMICRON 35, on M2/ M4.
In case these are all your personal lenses, you have quite a few treasures around
your place ... Or should we start calling it LEICA- Palace ?
best
GEORG
