stump4545 Posted July 31, 2013 Share #1 Â Posted July 31, 2013 Advertisement (gone after registration) is it a problem using say this 90mm macro handheld as minimum focus distance with or without the macro adapter which allows one to get super close? Â not sure if camera shake comes into play with macro lenses. first time. Link to post Share on other sites More sharing options...
Advertisement Posted July 31, 2013 Posted July 31, 2013 Hi stump4545, Take a look here Leica 90mm macro w/ adapter. I'm sure you'll find what you were looking for!
Karl G Posted July 31, 2013 Share #2 Â Posted July 31, 2013 No more a problem than any other lens at its absolute minimum focusing distance. If you are handheld and you lean in slightly from mfd, you will get an OOF picture. The adapter just lowers the mfd from .9m to .7m from memory, I would have to look up the exact spec on that. Link to post Share on other sites More sharing options...
lct Posted July 31, 2013 Share #3 Â Posted July 31, 2013 ...The adapter just lowers the mfd from .9m to .7m from memory... From 0.76 to 0.5m with the adapter http://tinyurl.com/nm53orw Link to post Share on other sites More sharing options...
stump4545 Posted July 31, 2013 Author Share #4 Â Posted July 31, 2013 how is the using the adapter? Â is the adapter a hassle or worth the benefit of getting to .5m? Link to post Share on other sites More sharing options...
tgray Posted August 1, 2013 Share #5 Â Posted August 1, 2013 I used to own this lens and the adapter. Without the adapter, the lens is a great little travel 90. Small, optically wonderful, and allows you to get pretty close. With the adapter, you can do passable closeups of something about the size of a 3x5" index card, if I recall correctly. I didn't use the adapter very much, but when I did, it worked out great. Â One thing to keep in mind if you are using an external meter is that the amount of light the lens is putting on film/sensor drops as you focus closer and closer. I think it was about a stop less when at the minimum focus distance with the adapter. This shouldn't be too much of an issue with TTL metering. Handholding wasn't much of an issue with good light as long as you kept your shutter speeds up. Â It really does take the M system somewhere where it's somewhat difficult to get to, at least pre M 240. If I had one of those, I might be tempted to instead get the R adapter and an R Macro lens. Though the 90 Macro is still incredibly portable, so is ideal for a travel lens if you are more of a 50/28mm shooter. I might think if you use the 75 Summicron alot, you could probably get by without the 90 Macro, but everyone thinks differently, so what do I know. Â I originally purchased just the lens (used) and later picked up the adapter (also used I think). It ended up being a good move, because not only did it come in handy a few times, but when I went to sell the set, I was able to get a pretty good price on the whole setup (lens, adapter, and angle magnifier). Link to post Share on other sites More sharing options...
stump4545 Posted August 1, 2013 Author Share #6 Â Posted August 1, 2013 thanks for the info. Â much appreciated! Link to post Share on other sites More sharing options...
MarkP Posted August 2, 2013 Share #7 Â Posted August 2, 2013 Advertisement (gone after registration) Though the 90 Macro is still incredibly portable, so is ideal for a travel lens if you are more of a 50/28mm shooter. . Â Exactly! Link to post Share on other sites More sharing options...
Mr_Jones Posted August 2, 2013 Share #8  Posted August 2, 2013 It's a fantastic lens, the macro adaptor is the main reason I bought it but the lens on its own is great for travel. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/209972-leica-90mm-macro-w-adapter/?do=findComment&comment=2388681'>More sharing options...
Hosermage Posted August 3, 2013 Share #9  Posted August 3, 2013 From my limited experience shooting with the adapter, I had more problem with my body swaying than my hand shaking. Maybe because I was bending down to take shots.. my back was sore afterwards from trying to hold my position while making sure the focus is right. Like other said, it is a wonderful travel lens.  Oh ya, and the framelines are not accurate at close distance for obvious reasons.  Here's a shot at min distance of a orchid, so you can get a sense of how close it gets: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/209972-leica-90mm-macro-w-adapter/?do=findComment&comment=2389209'>More sharing options...
stump4545 Posted August 3, 2013 Author Share #10 Â Posted August 3, 2013 without the adaptor, does .78m with a 90mm lens seem macro close in use? Â Â opinion, to shoot some newborn baby photos close up would the adaptor come in handy? Â thanks! Link to post Share on other sites More sharing options...
