biglouis Posted March 24, 2007 Share #1 Â Posted March 24, 2007 Advertisement (gone after registration) I wonder if anyone can give me some advice about this issue. I bought a s/h Elmarit 2.8 28mm and it came with the clip on lens hood. Before receiving the lens I also bought a B+W slimline UV 49mm filter. Unfortunately, the B+W filter whilst fitting the lens has a lip which prevents use with the lens hood. Â My question is, if I invest in the Leica E49mm UV filter, will it have the same problem or will I be able to get my lens hood over the filter. Â Clearly, my point here is to protect the lens. Â I have to also wonder if the lens hood is necessary - what are the opinions about that? Â LouisB Link to post Share on other sites More sharing options...
Advertisement Posted March 24, 2007 Posted March 24, 2007 Hi biglouis, Take a look here Filter for 28mm elmarit 2.8. I'm sure you'll find what you were looking for!
Shootist Posted March 24, 2007 Share #2  Posted March 24, 2007 I wonder if anyone can give me some advice about this issue. I bought a s/h Elmarit 2.8 28mm and it came with the clip on lens hood. Before receiving the lens I also bought a B+W slimline UV 49mm filter. Unfortunately, the B+W filter whilst fitting the lens has a lip which prevents use with the lens hood. My question is, if I invest in the Leica E49mm UV filter, will it have the same problem or will I be able to get my lens hood over the filter.  Clearly, my point here is to protect the lens.  I have to also wonder if the lens hood is necessary - what are the opinions about that?  LouisB  First off the 28/2.8 takes a 39mm filter, not a 49mm, E39, I'm looking at mine right now and it says E39. Not sure how you are making a 49mm filter work on a Leica 28/2.8 Elmarit as the correct filter size is 39mm. Yes the correct size Leica filter will work with the hood. The Leica filter mounting rings are smaller then all others, IE they are made to work with Leica lenses and hoods. Link to post Share on other sites More sharing options...
biglouis Posted March 24, 2007 Author Share #3  Posted March 24, 2007 First off the 28/2.8 takes a 39mm filter, not a 49mm, E39, I'm looking at mine right now and it says E39. Not sure how you are making a 49mm filter work on a Leica 28/2.8 Elmarit as the correct filter size is 39mm.Yes the correct size Leica filter will work with the hood. The Leica filter mounting rings are smaller then all others, IE they are made to work with Leica lenses and hoods.  Don't wish to contradict you but your version may take a 39mm filter but mine takes a 49mm. Here is what the Leica M guide says at Cameraquest for my version of 28/2.8 Elmarit:  "Third Version 1979 to 1993, Black, nose of lens is very large and straight. Lens barrel does not rotate as it is focused. usable on M5 and M6 49 mm filter ring. Reputed to be a big improvement over earlier versions. 8 elements."  Thanks anyway, I'll take the plunge and try a Leica 49mm  Cheers  LouisB Link to post Share on other sites More sharing options...
Shootist Posted March 24, 2007 Share #4 Â Posted March 24, 2007 OK you have the older version. I have the newer ASPH. Sorry for the confusion but as to what I said about the Leica filter still holds. Link to post Share on other sites More sharing options...
Leicanomad Posted March 24, 2007 Share #5 Â Posted March 24, 2007 Hi, I recently bought a second hand 28mm/2.8. It came with a Cokin 49mm 'Skylight 1A' filter. The hood slides over that without any problems. Not as good as a Leica filter but maybe worth bearing in mind if you can't get hold of the Leica. Â - Jim Link to post Share on other sites More sharing options...
cbretteville Posted March 26, 2007 Share #6 Â Posted March 26, 2007 I have this version of the 28 Elmarit. When I bought it it came with a Leitz UVa (expect that is of the same vintage as the lens). It fits inside the hood without any problem. I didn't like the results I got with the lens, it would flare something awful. So I have hardly used it on my M6. Â After playing around with it on my M8, I took the UV filter off and it is now a completely different lens. I get very enjoyable results. And it dosen't flare anywhere near as often or as much as it did with the old filter. Â My point is this, you may be able to find an old Leitz filter that fits inside the hood. If you must have an UV filter on it, get a modern one and save your self from ruined shots. If you can't get one that fits inside the old hood, get a 49mm screw on hood or don't use a filter at all. Â Just my NOK0.02. Â - Carl Link to post Share on other sites More sharing options...
luigi bertolotti Posted March 26, 2007 Share #7  Posted March 26, 2007 Advertisement (gone after registration) I wonder if anyone can give me some advice about this issue. I bought a s/h Elmarit 2.8 28mm and it came with the clip on lens hood. Before receiving the lens I also bought a B+W slimline UV 49mm filter. Unfortunately, the B+W filter whilst fitting the lens has a lip which prevents use with the lens hood. My question is, if I invest in the Leica E49mm UV filter, will it have the same problem or will I be able to get my lens hood over the filter.  Clearly, my point here is to protect the lens.  I have to also wonder if the lens hood is necessary - what are the opinions about that?  LouisB  For what You say,I suppose the Elmarit 28 is like mine : a "3rd type" (Canada,yellow "28" engraving round the lens base) : I confirm that with the original E49 filters you can clip-on the hood, for filter ring is very thin; I think that there are anyway filters of other brands made in such a manner: I have an orange E43 marked B&W that allows the mounting of the clip-on hood of my "old" Summilux 50. Link to post Share on other sites More sharing options...
wizard Posted March 27, 2007 Share #8 Â Posted March 27, 2007 Any 49mm filter which has an outer diameter not larger than the front rim of the lens should in fact be fine. I am surprised that your B+W slimline filter has some sort of ledge, as mine for the 24mm lens (filter size is 55mm) does not. My lens hood fits over the filter without problems. B+W filters are in fact as good as it gets, their antireflective coating is superior to the Leica filters, so you should probably try to get hold of a suitable B+W filter. Â Cheers, Â Andy Link to post Share on other sites More sharing options...
Giuliano De Portu Posted February 5, 2019 Share #9  Posted February 5, 2019 I have the v3 version. It says E49 on the side and I also have a HOYA UV(0) 49mm filter. Mainly to protect the lens. Anyone have the specs on the lens cap for this lens? Thanks! Link to post Share on other sites More sharing options...
jaapv Posted February 5, 2019 Share #10  Posted February 5, 2019 Any 49 mm snap-on lenscap will fit. $0.99 on ebay...  https://www.ebay.com/b/Unbranded-Snap-on-Camera-Lens-Caps-49-mm-To-Fit-Lens-Front/79001/bn_7112892529 1 Link to post Share on other sites More sharing options...
Herr Barnack Posted May 1, 2019 Share #11  Posted May 1, 2019 Quote ...Clearly, my point here is to protect the lens. I have to also wonder if the lens hood is necessary - what are the opinions about that? IMHO, lens hoods are necessary. They not only help to control flare and enhance image contrast, but they also provide a significant degree of front element protection for everyday shooting. If you are shooting in a dusty, windblown environment, a UV filter should also be used with the lens hood. I have always used both a UV filter and a lens hood on my wide lenses that I would use for event, documentary and street photography - focal lengths like 21, 28 and 35. I have found that if I screw on the UV filter first and then attach the lens hood, they can both be fitted to the lens. If your clip on lens hood still refuses to work with the UV filter in place, you might consider getting a B+W metal lens hood made for wide angle lenses. If it is a different thread diameter from your UV filter, you can mate the two by using a step up or step down ring. Link to post Share on other sites More sharing options...
UliWer Posted May 1, 2019 Share #12 Â Posted May 1, 2019 (edited) I tried a B+W XS Pro-Digital filter with 49mm - which is rather slim - and a F-Pro filter from B+W, which is not slim. With both versions the hood - No. 12536 - fits. Edited May 1, 2019 by UliWer Link to post Share on other sites More sharing options...
