jpbeer Posted November 5, 2010 Share #1 Â Posted November 5, 2010 Advertisement (gone after registration) Hi all, Â It seems that my Elmarit M 90 has a problem with the front cap. The cap fits the lens well, but when the UVa filter is on, it is almost impossible to fit the cap. Â I never really noticed this issue til now. Does anybody here know if this is something specific to this lens-filter-cap combination? Or did I just get a faulty cap when I bought the lens new? Link to post Share on other sites More sharing options...
Advertisement Posted November 5, 2010 Posted November 5, 2010 Hi jpbeer, Take a look here Elmarit M 90 (last generation). I'm sure you'll find what you were looking for!
250swb Posted November 5, 2010 Share #2  Posted November 5, 2010 You mean it always wants to fall off if you have a filter fitted? That sounds about right, mine does as well. The solution is not to fit the cap other than for storage at home  Steve Link to post Share on other sites More sharing options...
dsj Posted November 5, 2010 Share #3 Â Posted November 5, 2010 i have this problem with all my lenses and all my lenscaps. they are all 39mm filter mounts and 3 different kinds of caps. one rubbercap doesn't work to bad though. Link to post Share on other sites More sharing options...
jpbeer Posted November 5, 2010 Author Share #4 Â Posted November 5, 2010 I meant to say that the diameter of the front part of the filter appears to be slightly less than the lens thread, which makes it difficult to fit the lens cap delivered with the lens. It never bothered me though. Â I am asking this, because I just sold the lens which is in a top A1 condition and the person who bought it is making a big fuss over the cap and filter issue, claiming that the functionality of the lens is impaired. He wants to send it back to me due to this problem. Link to post Share on other sites More sharing options...
cbretteville Posted November 5, 2010 Share #5 Â Posted November 5, 2010 I have had 46mm B+W F-PRO uv and uv/ir filters on mine and have never had any issues with the lens cap. Carl Link to post Share on other sites More sharing options...
LMBSGV Posted November 6, 2010 Share #6  Posted November 6, 2010 I had a similar problem and solved it (cheaply) with this:  New 2 x 46mm Snap-on Lens Cap Set  You can also buy a set of ten:  New 10 x 46mm Snap-on Lens Cap Set Link to post Share on other sites More sharing options...
Shootist Posted November 6, 2010 Share #7  Posted November 6, 2010 Advertisement (gone after registration) I meant to say that the diameter of the front part of the filter appears to be slightly less than the lens thread, which makes it difficult to fit the lens cap delivered with the lens. It never bothered me though. I am asking this, because I just sold the lens which is in a top A1 condition and the person who bought it is making a big fuss over the cap and filter issue, claiming that the functionality of the lens is impaired. He wants to send it back to me due to this problem.  I'd say it is a filter problem not a cap or lens problem. I have this lens with a IR blocking filter on it, used on a M8, and the cap functions find with or without the filter attached.  Tell the buyer to take the filter off. Link to post Share on other sites More sharing options...
jaapv Posted November 6, 2010 Share #8 Â Posted November 6, 2010 Not a reason to accept a return imo. Link to post Share on other sites More sharing options...
jpbeer Posted November 7, 2010 Author Share #9 Â Posted November 7, 2010 Apparently, there seem to be some random problems with cap and filters. Â Thanks to all of you. It helps. Link to post Share on other sites More sharing options...
luigi bertolotti Posted November 7, 2010 Share #10 Â Posted November 7, 2010 Strange issue... my Elmarit M 90 has the std Leica UVIR (13418) and the std. lens cap (14231) that, thanks to the spring-loaded retainers, is perfectly stable onto the filter: which kind of filter is the UVa you quote ? In my opinion, if it is not a Leica original, the buyer has not reason to complain...(none can pretend 100% compatibility with a 3rd party item) , and if it is... well, given that the cap is ok on the lens, you maybe could be such a gentleman to accept the return of the filter only, at the reasonable value of a used filter, no more... Alternatively, should the heavystar cap above quoted solve the issue, spend the few dollars it costs and send it to the buyer... Link to post Share on other sites More sharing options...
glenerrolrd Posted November 8, 2010 Share #11 Â Posted November 8, 2010 Talk about a buyer working on the wrong problem. He probably didn t test the lens to see if the focus calibration was on or if the image field was flat. Â I never use the caps unless I am traveling ..but isn t it possible that the cap or the outside filter thread was damaged by fussing with the cap. I would start with trying another filter and another cap . Â If it was me I would just accept the lens back and resell it. Link to post Share on other sites More sharing options...
