SJP Posted September 6, 2009 Share #21 Posted September 6, 2009 Advertisement (gone after registration) Isn't the circle of confusion set by the pixel size instead of the sensor size.Since the pixel size did not change, so did the circle of confusion stay the same? Hans No the circle of confusion is governed by the sensor size & to what extent you wish to examine your large size print with a microscope e.g. to count all your cat's whiskers. The bog standard CoC on which the lens barrel markings are based is 31 micron for Leica lenses as far as I can compute. That will be the same for the M9. With the M8 you needed to compensate by (very roughly) 1 stop. Most of us add 1 stop extra for reasons of pixel peeping. So for the M9 about 1 stop safety margin would be the operative procedure. Link to post Share on other sites More sharing options...
Advertisement Posted September 6, 2009 Posted September 6, 2009 Hi SJP, Take a look here M9 easier to focus than M8. I'm sure you'll find what you were looking for!
t024484 Posted September 6, 2009 Share #22 Posted September 6, 2009 No the circle of confusion is governed by the sensor size & to what extent you wish to examine your large size print with a microscope e.g. to count all your cat's whiskers. The bog standard CoC on which the lens barrel markings are based is 31 micron for Leica lenses as far as I can compute. That will be the same for the M9. With the M8 you needed to compensate by (very roughly) 1 stop. Most of us add 1 stop extra for reasons of pixel peeping. So for the M9 about 1 stop safety margin would be the operative procedure. What about this article, Diffraction Limited Photography: Pixel Size, Aperture and Airy Disks are they wrong in their assumptions? Hans Link to post Share on other sites More sharing options...
SJP Posted September 6, 2009 Share #23 Posted September 6, 2009 What about this article,Diffraction Limited Photography: Pixel Size, Aperture and Airy Disks are they wrong in their assumptions? Hans No at a glance the article is just fine. The point is that diffraction is normally much smaller that what we need to make a sharp image (or at least something that appears sharp). For the M* the size of the circle of confusion (required to make an acceptably sharp image) is quite a bit larger than diffraction limits except at f/8 or f/11. So for largish sensors difraction is not really a factor to consider. For small sensors like in P&S, the stuff that 99.99% of the population use, diffraction is a major issue. Link to post Share on other sites More sharing options...
lct Posted September 6, 2009 Author Share #24 Posted September 6, 2009 For a CoC calculator, see Circles of Confusion for Digital Cameras Link to post Share on other sites More sharing options...
jaapv Posted September 7, 2009 Share #25 Posted September 7, 2009 No the circle of confusion is governed by the sensor size & to what extent you wish to examine your large size print with a microscope e.g. to count all your cat's whiskers. The bog standard CoC on which the lens barrel markings are based is 31 micron for Leica lenses as far as I can compute. That will be the same for the M9. With the M8 you needed to compensate by (very roughly) 1 stop. Most of us add 1 stop extra for reasons of pixel peeping. So for the M9 about 1 stop safety margin would be the operative procedure. Yes- that one stop will take the difference in the appearance of DOF between film an sensor into account. We must consider, however, that the 0.3 mm is based on a final print of 6x9 cm. So as long as you don't print larger, you will be fine. Link to post Share on other sites More sharing options...
t024484 Posted September 7, 2009 Share #26 Posted September 7, 2009 Yes- that one stop will take the difference in the appearance of DOF between film an sensor into account. We must consider, however, that the 0.3 mm is based on a final print of 6x9 cm. So as long as you don't print larger, you will be fine. You probably mean 0.03 mm and 6*9 inch ? Link to post Share on other sites More sharing options...
jaapv Posted September 7, 2009 Share #27 Posted September 7, 2009 Advertisement (gone after registration) Yes, 0.03 mm Thanks for correcting the typo . And no, the original figure is based on 1930-ies 6x9 cm enlargements. It is wildly optimistic for current-day photography. The supposed reason that it was never changed is that lens makers felt that the public would see any new standard as "modern lenses are worse quality". Link to post Share on other sites More sharing options...
t024484 Posted September 7, 2009 Share #28 Posted September 7, 2009 For a CoC calculator, see Circles of Confusion for Digital Cameras Thanks. I started from the wrong side, that is with the sensor. One shoulds start with the vision capability of men, which roughly has a CoC of 0.2mm when looking at a picture of 8*10 inch wide from a distance of 25cm. Any detail below this figure of 0.2mm will we perceived as being sharp. Going back from there to a 24*36 sensor this translates in approx. 37,5 lp/mm or 1800 LW/PH. The M9 will easily outperforms this figure, having probably something like 2800 LW/PH, or 58 lp/mm, but are FF lenses capable of resolutions this high ? If so, the sensor will outperform the available lenses, which is not bad. Hans Link to post Share on other sites More sharing options...
