GMB Posted August 19, 2009 Share #61 Posted August 19, 2009 Advertisement (gone after registration) I would send the lot to Will. Faster and cheaper and as least as good. Who is is Will -- if I may ask? My problem is that i wonder whether my unstable results are because I do not have the right technique or because something is wrong the camera or the lenses. Link to post Share on other sites More sharing options...
Advertisement Posted August 19, 2009 Posted August 19, 2009 Hi GMB, Take a look here M8-Focus on focussing . I'm sure you'll find what you were looking for!
adli Posted August 19, 2009 Share #62 Posted August 19, 2009 Who is is Will -- if I may ask? My problem is that i wonder whether my unstable results are because I do not have the right technique or because something is wrong the camera or the lenses. A tripod should give you the answer Link to post Share on other sites More sharing options...
Jamie Roberts Posted August 19, 2009 Share #63 Posted August 19, 2009 Indeed we are talking different things here. If professional, I would not chance missing those shots either, even if it were my fault and not the camera's Even as an amateur I would opt for certainty. Except I do those kind of shots all the time with both a D3 and the M8. And I don't miss them when I use the M8 due to focus. I might miss due to reach (past 90 nothing is reliable on the M8)--or even miss them to low light if I don't want to use flash; but not to focus. With all due respect, in neither of Rolo's shots is the subject moving in the slightest, and in neither of them I'm not seeing something very wide open. So given a 35 or 50 Lux on the M8, and some way of getting f2.8 or 3.2, you are as certain of focus with the RF as you would be with the dSLR in those situations. YMMV. Link to post Share on other sites More sharing options...
Jeff S Posted August 19, 2009 Share #64 Posted August 19, 2009 Who is is Will I think this refers to index.html Jeff Link to post Share on other sites More sharing options...
lxlim Posted August 20, 2009 Share #65 Posted August 20, 2009 Except I do those kind of shots all the time with both a D3 and the M8. And I don't miss them when I use the M8 due to focus. I might miss due to reach (past 90 nothing is reliable on the M8)--or even miss them to low light if I don't want to use flash; but not to focus. With all due respect, in neither of Rolo's shots is the subject moving in the slightest, and in neither of them I'm not seeing something very wide open. So given a 35 or 50 Lux on the M8, and some way of getting f2.8 or 3.2, you are as certain of focus with the RF as you would be with the dSLR in those situations. YMMV. I agreed with Rolo because I am primarily still prefer to use a DSLR when dealing with combination of: 1. clients who I am largely unfamiliar with 2. events unfold unexpectedly 3. long stretch of 8 hours or more 4. Rapid ISO changes might be needed. 5. Flash My corporate clients' events are usually fast paced but after years of working with them I know what they want. I know what I can get away with not covering. Sometimes its DRF sometimes its DSLR. At the end of the day, I am still building my competency in using the rangefinder I don't think I will reach anywhere as good as you or many on this forum If the M8 has ISO 2500 like its 640, that will make a huge difference to me. Weddings, if I were to do them needs a DSLR shooter paired with me and an assistant with a pocket wizard triggered Qflash on a monopod. Link to post Share on other sites More sharing options...
diogenis Posted August 20, 2009 Share #66 Posted August 20, 2009 Jaap, I had recently have one idea for a possible focus improvement over RF and leicas, and maybe MarkNorton could confirm us how easy it would be to implement it. Here it is: First, I am real happy about how fast and accurate the mechanism is, but indeed there are occassions where (myself included) one hunts for vertical lines. Would it be possible to improve the central yellowish patch to indicate both vertical and horizontal displacement maybe in a separated patch? Like two patches one for horiz one for vertical movement? Link to post Share on other sites More sharing options...
diogenis Posted August 20, 2009 Share #67 Posted August 20, 2009 Advertisement (gone after registration) Rolo and Jaap as for the wedding photos, every system embeds a possible error according to complexity. So, there is a chance that something might go wrong and lose the prescious moment. on a RF however, all one has to do is to allign correctly two images. If you can do this fast enough, then you can take 4-5 shots of that wedding ring Rolo. It is a matter of practice, something you already know by shooting weddings arent you? For me, capturing these dogs would be more difficult than the wedding ring. The wedding ring on the other hand is indeed a moment in time quite small, but you expect it to happen, you almost know when it will occur. Link to post Share on other sites More sharing options...
adan Posted August 20, 2009 Share #68 Posted August 20, 2009 I'll just toss in that's there is a difference between aligning a split-image in an SLR screen (more or less Leica-like) and just trying to focus on a ground-glass. I never used anything but a split-image in my Nikon/Canon days - until the very end, when they disappeared (hello, rangefinders!) There is - somewhere, but I haven't seen it in 20 years - a formula for split-image SLR screens. Maybe it's the one jaapv gave. Does include lens focal length. With a nice big pre-AF SLR view (45mm eyepiece focal length, no "high-eyepoint" BS) the SLR split would match an RF at about 90mm f/2. And generally I had no problem all the way down to 16 fisheyes - with the split. There is a weird dynamic where the faster the lens, the easier SLR focusing is, whereas, the faster the lens, the HARDER RF focusing is. Easy way to find out the focal length of an SLR eyepiece. Put on a zoom including the 30-60mm range (True focal lengths, not "equivalents"), look through the eyepiece with both eyes open, and zoom until the viewfinder image is exactly the same size/scale as your natural view with the other eye. Then check the zoom setting (carefully, without moving it). Generally, they are a bit longer than 55mm. But good pro SLRs c. 1980 (F-1, F2) usually had 50mm eyepieces. Olympus went even shorter, which is what made for that HUGE screen inside the tiny OM series. About a 45mm eyepiece focal length. Modern APS-crop cameras should have had the eyepiece focal length reduced to 35mm or 33mm (the new normal) to increase magnification. Most have not (although the Nikon D80/90 have improved a bit) so the view is of a tiny postage stamp. If Maitani (designer of the OM series) saw an Oly E-3 viewfinder, he'd weep! Link to post Share on other sites More sharing options...
adli Posted August 20, 2009 Share #69 Posted August 20, 2009 Would it be possible to improve the central yellowish patch to indicate both vertical and horizontal displacement maybe in a separated patch? Like two patches one for horiz one for vertical movement? Then the camera has to contain a vertical rangefinder in addition to the horizontal. If you look at the front of your camera the rangefinder mechanism is in the top of your camera between the rangefinder vindow and the viewfinder window. Building a vertical rangefinder means that you need a rangefinder window at the same distance above or bellow the viewfinder window. This will obvoiusly not fit into an M-body. An other problem is that the rangefinder patch i displayed in the viewfinder with a mirror. Using two mirrors in two different angles will complicate things further. Unless you want to go back to the pre-war Leicas with separate rangefinder and viewfinder windows, but wants that. Look up any good book on rangefinders, and you will sew the complexity of the rangefinder mechanism (I personally recomend Gunter Osterloh - Leica M: Advanced Photo School). Link to post Share on other sites More sharing options...
jaapv Posted August 20, 2009 Author Share #70 Posted August 20, 2009 Jaap,I had recently have one idea for a possible focus improvement over RF and leicas, and maybe MarkNorton could confirm us how easy it would be to implement it. Here it is: First, I am real happy about how fast and accurate the mechanism is, but indeed there are occassions where (myself included) one hunts for vertical lines. Would it be possible to improve the central yellowish patch to indicate both vertical and horizontal displacement maybe in a separated patch? Like two patches one for horiz one for vertical movement? Well, this thing in the hot shoe? Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/93763-m8-focus-on-focussing/?do=findComment&comment=999140'>More sharing options...
lxlim Posted August 20, 2009 Share #71 Posted August 20, 2009 I'll just toss in that's there is a difference between aligning a split-image in an SLR screen (more or less Leica-like) and just trying to focus on a ground-glass. I never used anything but a split-image in my Nikon/Canon days - until the very end, when they disappeared (hello, rangefinders!) There is - somewhere, but I haven't seen it in 20 years - a formula for split-image SLR screens. Maybe it's the one jaapv gave. Does include lens focal length. With a nice big pre-AF SLR view (45mm eyepiece focal length, no "high-eyepoint" BS) the SLR split would match an RF at about 90mm f/2. And generally I had no problem all the way down to 16 fisheyes - with the split. There is a weird dynamic where the faster the lens, the easier SLR focusing is, whereas, the faster the lens, the HARDER RF focusing is. Easy way to find out the focal length of an SLR eyepiece. Put on a zoom including the 30-60mm range (True focal lengths, not "equivalents"), look through the eyepiece with both eyes open, and zoom until the viewfinder image is exactly the same size/scale as your natural view with the other eye. Then check the zoom setting (carefully, without moving it). Generally, they are a bit longer than 55mm. But good pro SLRs c. 1980 (F-1, F2) usually had 50mm eyepieces. Olympus went even shorter, which is what made for that HUGE screen inside the tiny OM series. About a 45mm eyepiece focal length. Modern APS-crop cameras should have had the eyepiece focal length reduced to 35mm or 33mm (the new normal) to increase magnification. Most have not (although the Nikon D80/90 have improved a bit) so the view is of a tiny postage stamp. If Maitani (designer of the OM series) saw an Oly E-3 viewfinder, he'd weep! If there are no verticals, how do you normally focus with the SLR split? Thanks, for the input. Link to post Share on other sites More sharing options...
jaapv Posted August 20, 2009 Author Share #72 Posted August 20, 2009 The formula quoted is valid for all focussing aids, including split image and microprisms. There are very few real matte screens out there. The only ones I can think of are the Visoflex and the Leicaflexes and some other very old SLR cameras (EXA, early Praktica, Praktina, etc). Most others are fresnel screens, and then the formula applies. The whole story about focussing on a screen is quite elaborate, and would take an impossibly long post to explain. Link to post Share on other sites More sharing options...
Nicoleica Posted August 20, 2009 Share #73 Posted August 20, 2009 If there are no verticals, how do you normally focus with the SLR split? Thanks, for the input. The same way as I do with a rangefinder. Tilt the camera. (Of course, most modern SLR manual focussing screens have a 45 degree split image anyway.) Link to post Share on other sites More sharing options...
jaapv Posted August 20, 2009 Author Share #74 Posted August 20, 2009 Coincidence focussing? Contrast focussing? Link to post Share on other sites More sharing options...
jaapv Posted August 20, 2009 Author Share #75 Posted August 20, 2009 I think this refers to index.html Jeff Indeed. Thanks, Jeff Link to post Share on other sites More sharing options...
lct Posted August 20, 2009 Share #76 Posted August 20, 2009 Yes 50mm, 45mm or less but i've never heard of the 60mm value of Jaap's EFL (eyepiece focal length) value so far. ...Generally, they are a bit longer than 55mm. But good pro SLRs c. 1980 (F-1, F2) usually had 50mm eyepieces. Olympus went even shorter, which is what made for that HUGE screen inside the tiny OM series. About a 45mm eyepiece focal length.Modern APS-crop cameras should have had the eyepiece focal length reduced to 35mm or 33mm (the new normal) to increase magnification... Link to post Share on other sites More sharing options...
jaapv Posted August 20, 2009 Author Share #77 Posted August 20, 2009 Leica R has 61.53 (official specification by Leica) Link to post Share on other sites More sharing options...
diogenis Posted August 20, 2009 Share #78 Posted August 20, 2009 Well, this thing in the hot shoe? Lol.. of course not: I am talking about an elegant solution here, like maybe a lens that can turn image 90degrees and ofcourse be coupled with the main RF mechanism. I dont know.. just an idea. I' m perfectly happy with how the RF works on this camera. It's simple and accurate- very accurate. Even if they could make two patches one vertical and one horiz, even then that would add a complication most might not need edit: where did you found that thing Link to post Share on other sites More sharing options...
lct Posted August 20, 2009 Share #79 Posted August 20, 2009 If there are no verticals, how do you normally focus with the SLR split? Thanks, for the input. Yes tilt the camera or choose a diagonal split image focus screen instead (here from Brightscreen). Link to post Share on other sites More sharing options...
jaapv Posted August 20, 2009 Author Share #80 Posted August 20, 2009 Lol.. of course not: I am talking about an elegant solution here, like maybe a lens that can turn image 90degrees and ofcourse be coupled with the main RF mechanism. I dont know.. just an idea. I' m perfectly happy with how the RF works on this camera. It's simple and accurate- very accurate. Even if they could make two patches one vertical and one horiz, even then that would add a complication most might not need edit: where did you found that thing Collecttable cameras is selling it. It would be very difficult. One would need an extra window at the bottom of the camera with an unobstructed view (hands??) and the projecting lens would have to swivel in two dimensions instead of just horizontally like now. In actual fact it is really quite impossible to build for a camera. It might be done for a naval gun, but there radar has taken over. If you just want to turn the orientation of the rangefinder, it is just as impossible, as it will always work parallel to the connecting line between the rangefinder windows. Link to post Share on other sites More sharing options...
