Sign in to follow this
psquared
M9: Does Phase One Know Something?
I recently installed Capture One Pro 4.8.2 (Windows Vista). I went into the Color Profiles folder to rename "Leica M8-Generic UV-IR.icm" as "Leica M8-Generic.icm" so that it becomes my default color profile for M8. Well, what do you know? There is a file called "Leica M9-Generic.icm" dated 7/6/09. Furthermore, there is no UV-IR equivalent for M9. Do they know something?
In Windows Vista 64-bit, the folder is "Program Files(x86)\Phase One\Capture One 4\Color Profiles\DSLR".
Share this post
Thanks for this information! I still cannot believe that a M9 is finally coming this fast...
Share this post
Just installed Mac 4.8.2 version and there is no M9 profile in it. Profiles just went from M8 variants to R8 and R9. Checked by using the 'Show Package Contents'.
Edited by RoyP
Share this post
On the Mac the application is a special folder that looks like an ordinary file. You highlight the file (in this case Capture One and from the file menu select 'Show Package Contents'. This then shows it as a normal folder with sub folders and files contained within it.
In this case open 'Contents' folder and then 'Resources' folder and then open 'Profiles folder'. Two folders are within this one 'Input' the other 'Output'. All the camera profles are in the Input folder.
It's easier to do than explain. And yes M9 is not in the Mac version.
Share this post
mmm... no profiles for the M9 in the Mac Capture One 4.8.2 ...
Share this post
This shot from Mac C1 4.8.2. No M9 listed also checked C1 Pro profiles folder. Must be PC only for now.
Share this post
I wonder what we can tell about the M9 by looking inside the icm-file?
Does anybody know how to read them?
Regards
Per
Share this post
I've checked the M9 profile using ICC inspector and MATLAB, it's an exact copy of the M8 generic profile which was created on July 17, 2006.
My guess is it's either a space holder (unlikely) or a prank Phase played with the M aficionados.
Share this post
Why a Phaseone prank and not a placeholder that shouldn't have been turned on?
Curious if any previous C1 versions include reference to M9?
Share this post
I just installed 4.8. It does not show a profile for an M9.
Share this post
Good to know. Thank you for checking.
Share this post
I'd tend to agree. If (1) anything in the M9 improved over the M8, and (2) PhaseOne had actual knowledge of the characteristics of the M9, the files would be different.
Is there bad blood between PhaseOne and Leica following the S2 breakup? Would that prompt a prank?
Share this post
Actually, I need to apologize for my previous post ... sore eyes and quick post without careful looking.
The M8 generic and M9 generic are indeed different profiles, many tag values are different, although the file timestamp in Windows shows it was tampered with on July 6th, 2009, the actual header info indicates but both profiles were created on the same date at the same time (2006/07/17, 16:42:01), so it's really an old profile created back in 2006 - I have no idea what's going on here.
The M8 UV/IR profile was created on 2007/06/28, 9:44:38.
Edited by sdai
Share this post
Just checked:
On mine, there is.
Cheers,
Uwe
Share this post
Just checked:
On mine, there is.
Cheers,
Uwe
Are you sure Uwe you did not confuse it with the R9 profile?
Share this post
Loading...
    No registered users viewing this page.
