photophile Posted June 26, 2009 Share #1 Posted June 26, 2009 Advertisement (gone after registration) I have slowly converted my older lenses ( 50 and wider ) to six bit code. I still do not see aperature setting in LR2. M8 set to lens on/uv/ir. Should it be there or is there a modification in LR that must be set? Thanks in advance. Link to post Share on other sites More sharing options...
Advertisement Posted June 26, 2009 Posted June 26, 2009 Hi photophile, Take a look here aperature info with 6 bit coding in LR?. I'm sure you'll find what you were looking for!
jev Posted June 27, 2009 Share #2 Posted June 27, 2009 you need something like exiftool and a simple script to write the lens information, it takes about 2 minutes to do it my workflow is as follows shoot, shoot some more sort photos in Adobe Bridge by focal length and move in the different subdirectories i.e. 50mm etc. then run a script like that to populate lens information "exiftool -FocalLengthIn35mmFormat=15 -FocalLength=21 -Lens="Cosina/Voigtlander 15mm f4.5 Heliar" -DNGLensInfo="Cosina/Voigtlander 15mm f4.5 Heliar" -overwrite_original /Volumes/Macintosh\ HD/Users/xxx/Pictures/Wisc/15mm/" then move photos to LR by importing those This will give you a fully sortable information on lenses in LR or Aperture Have fun Link to post Share on other sites More sharing options...
photophile Posted June 27, 2009 Author Share #3 Posted June 27, 2009 Many thanks. Is there no "built-in" method in LR to read the full exif? Link to post Share on other sites More sharing options...
cbretteville Posted June 27, 2009 Share #4 Posted June 27, 2009 LE reads the full EXIF info for all the documented/public information tags (fields). The lens code and guesstimated aperture is written to a block of data that is not publicly documented (by Leica). This block is called the "maker notes". Allthough all the maker notes of the M8 is described in my report from 2007, this info has not been sanctioned by Leica. I don't think adobe decodes the maker notes from any camera. - Carl Link to post Share on other sites More sharing options...
photophile Posted June 27, 2009 Author Share #5 Posted June 27, 2009 Thank you Carl. Best. Coos Link to post Share on other sites More sharing options...
