Best 50mm lens?
ShivaYash
Hi,
I'm a long term user of the famous 4th version 35f2 - the king of bokeh.
What is the equivalent lens in the longer 50mm format?
I have been given an old 50f2 to try, before I buy, its serial number is 2519366 - so far the photos look amazing, I love the bokeh, just want to make sure I'm getting the right lens.
Thanks,
As your thread topic header reads "Best 50mm Lens".
That would be the current 50mm Summilux ASPH.
There is no better 50mm lens made by Leica or any other Camera/Lens manufacturer.
I have the Cron, Elmar and the Lux. The Lux see way more use then both of the others combined.
Thanks but by best, I don't necessarily mean sharpest.
I want a lens for street portraits on the M8, I love the 35/2, pre-ASPH, in my eyes, this is the BEST 35mm lens made, my version dates from 1991 but I think the photos I take with it beat those taken on a current 35/2 ASPH.
I want a sharp but warm, mellow feeling 50/2. I think I have already found it, the model I have now dates from 1972, but I need to take more portraits to be certain.
Just want to know what other users think I should try before I commit to buying.
Thanks,
50mm lenses are like Pizza's. They are all good, but what you prefer may vary. If you like the look of your V4 35mm Summicron I'd suggest the current Summicron 50. It has a smooth, creamy tonal rendition and it's performance is near perfect at all apertures.
Best wishes
Dan
Hi,
Thanks,
That means you have the right lens for you. The grass may seem greener at the other side of the fence, in reality itvrarely is..
I think as well the current Summicron, this mean from 1979 to now should be the äquiv. to the IV 35 'Cron.
But this is so subjective, if you find your lens in the type before, as you mentioned, nobody can say you are wrong, can they?
Cheers,
Eckart
The Summilux pre-ASPH has many of the qualities of the Ver.4 35 Cron.
Can be softish (at the edges) wide open, while sharp in the centre.
Is sharp edge to edge when stopped down.
Pleasant OOF rendition (not the same as "The King), but a very attractive look.
Both are Mandler designs BTW.
you're right about that....Sounds like the OP is already doing pretty well and doesn't really need an upgrade or replacement. The only time to get serious about new equipment is when the old equipment is no longer inspiring to use...
