brucek Posted May 29, 2009 Share #1 Posted May 29, 2009 Advertisement (gone after registration) Can anybody help? So far I've been unable to find a catalog number in any of my reference books. Looks like I have the M3 version (no goggles) and I'd like to try using the lens on my M7 and/or M8. Thanks. Link to post Share on other sites More sharing options...
Advertisement Posted May 29, 2009 Posted May 29, 2009 Hi brucek, Take a look here What lens shade for 35mm f/3.5 Summaron?. I'm sure you'll find what you were looking for!
TimF Posted May 29, 2009 Share #2 Posted May 29, 2009 You need to look for the IROOA (or 12571) shade. Your lens is the regular one; it's the M3 version that has the goggles. I see KEH have a couple listed, though eBay might be cheaper of course. Alternatively the more common 12585 hood will probably fit fine. Link to post Share on other sites More sharing options...
luigi bertolotti Posted May 29, 2009 Share #3 Posted May 29, 2009 If your lens is this, one of the hoods for it is the depicted one: IROOA - 12571 [ATTACH]143768[/ATTACH] That fits well many 35mm : I still use it on my Summicron 35 asph: very solid, very stable. Link to post Share on other sites More sharing options...
brucek Posted May 29, 2009 Author Share #4 Posted May 29, 2009 You need to look for the IROOA (or 12571) shade. Your lens is the regular one; it's the M3 version that has the goggles. Well, that's what I thought too. But in looking in Lager's Volume II Leica Lens book the markings on it are a perfect match for what is indicated to be the lens for the M3. I suppose there's no reason that the lens couldn't have been separated from the goggles at some point. Thanks! Link to post Share on other sites More sharing options...
brucek Posted May 29, 2009 Author Share #5 Posted May 29, 2009 Thanks for the replies. Now the hunt begins... Link to post Share on other sites More sharing options...
luigi bertolotti Posted May 29, 2009 Share #6 Posted May 29, 2009 Well, that's what I thought too. But in looking in Lager's Volume II Leica Lens book the markings on it are a perfect match for what is indicated to be the lens for the M3. I suppose there's no reason that the lens couldn't have been separated from the goggles at some point. Thanks! The FIRST Summaron 3,5 for M3 was un-goggled (like the one above) and needed external VF (typically, the SBLOO); goggled version arrived later. Anyway, the front ring, i.e., the hood too, is always the same. Link to post Share on other sites More sharing options...
jaapv Posted May 29, 2009 Share #7 Posted May 29, 2009 Advertisement (gone after registration) Well, that's what I thought too. But in looking in Lager's Volume II Leica Lens book the markings on it are a perfect match for what is indicated to be the lens for the M3. I suppose there's no reason that the lens couldn't have been separated from the goggles at some point. Thanks! In that case it would have a flat piece with a little ball in the middle on top of the mount, and would be permanently locked at infinity. Link to post Share on other sites More sharing options...
brucek Posted May 30, 2009 Author Share #8 Posted May 30, 2009 In that case it would have a flat piece with a little ball in the middle on top of the mount, and would be permanently locked at infinity. Ah. Well it doesn't have the flat piece nor is it locked at infinity. So Mr. Lager's book appears to have a misattribution for that particular lens. Thanks for the information! Link to post Share on other sites More sharing options...
leitz_not_leica Posted May 30, 2009 Share #9 Posted May 30, 2009 I remember my 35/3.5 having a clamp-on A-36 round hood, don't know the stock #. Link to post Share on other sites More sharing options...
luigi bertolotti Posted May 30, 2009 Share #10 Posted May 30, 2009 I remember my 35/3.5 having a clamp-on A-36 round hood, don't know the stock #. Well, this means it was the screw mount first version - filters and hoods fitted as in the Elmars. The Summaron's hood was coded as FOOKH. Link to post Share on other sites More sharing options...
microview Posted May 31, 2009 Share #11 Posted May 31, 2009 Can anybody help? So far I've been unable to find a catalog number in any of my reference books. Looks like I have the M3 version (no goggles) and I'd like to try using the lens on my M7 and/or M8. Thanks. The one I am in process of selling had a screw thread to take an E39 filter – earlier versions don't. I bought a B+W collapsible rubber hood (the lens is very prone to flare so some sort of hood is pretty essential); these are very inexpensive, and work well. A Leica hood I was also sold sat so close to the aperture ring that it made it difficult to change aperture settings easily. The B+W of course screwed either directly into the lens or into an E39 UV/IR filter. Link to post Share on other sites More sharing options...
