8 bit and 16 bit Files Question
jbm
As noted above, using 16-bit files gives more range for making global corrections, but has the disadvantage of taking up much more space.
I know some heavy-duty Photoshop users who use 16-bit files for all initial global adjustments, then save as 8-bit when getting closer to finished.
I've also attended Photoshop seminars where we were told 'just convert to 8-bit and don't worry about it.'
But David is right. Working in 16-bit is demonstrably better, though perhaps not enough so to be worth the disk space needed to store the files in that mode.
--HC
There are some Photoshop CS2 filters that don't work with 16-bit files.
Good point, JC! But each generation of CS2 expands the list of features that accommodate 16-bit files. And one can always switch into 16-bit mode to make less destructive modifications, while staying in 8-bit most of the time.
Basically, 8-bit is fine. For highest quality, stay in 16-bit as long as possible.
But since the question is whether to save to 16 bit from a noise reduction program, don't bother. Just go to 8-bit.
Theoretically, if working from RAW, you'd stay in 16-bit till all global adjustments were made, then move to 8-bit.
--HC
Does anyone can see a difference between 16 bits and 8 bits pics on prints or monitors?
LCT--
No, I don't think so. I believe most monitors and printers are fed 8-bit data anyway, or am I wrong?
But I've seen it demonstrated in Photoshop that making a given change--Curves, say--will cause greater data gaps in the histogram when beginning with an 8-bit original than when beginning with a 16-bit original.
In other words, if you've got more buckets to start with, you've got more room to spread the data.
I've seen it demo'ed, but I've basically dropped 16-bit practice from my workflow due to file size constraints.
--HC
