Stupid Fool
jaapv
Jaap,
You are near a 120mm with a 90mm on the M8.
Yes - but the 135 finder has reduced framelines for 1m. I would say that is about 150 mm at infinity. Plus these finders have the slide-film-mask cut-off of 1mm on the crop. I'll do some tripod testing. It might come close to the 135=180 on the M8 in that case.
One feature you should try with this type finder is keep both eyes opened. It is a 1:1 (also 9cm the same). You may enjoy this way to view, appears the frame to float in space whilst you see your normal view in front.
The VIOOU-type zooming finder has manual correction for close and far framing, and with the 135 setting "zoomed" that little extra bit, makes a very accurate 180 finder for distant shots.
It is, however, a tiny little window to frame through, has to be manually adjusted for parallax as well or the image is way off center, and is a basic PITA as well as being big and lumpy.
... sorry for continuing this partially unrelated chat about VFs (me and JC are accustomed to this on the historical section...:) )...
Confirm, my VIOOH has 8,5 (of course, together with the std 3,5 5 9 13,5) and VIDOM has both 7,3 and 10,5 (but THERE ARE a pair of VFs for 7,3 only... damn I haven't any...:( ). Laney lists 10 variants of the VIOOH... plus 3 for the Leitz N.Y sibling known as "Imarect"... yeah VFs are GREAT !!
I just found a fine SBOOI. It is my first for an individual focal length and i doubt whether my collection will ever be as large as those impressive lists i find here.
In the upper section of the frame i see four regular transparent marks, and i cannot make out what they are useful for. Is there any explanation for them?
"...four regular transparent marks, and i cannot make out what they are useful for"
Parallax correction. When you are focused very cloe to the subject (about 1-1.5 meters) use the four marks as the top of your picture to prevent cutting off tops of heads etc.
Remember that with an RF, the lens will see the world from 2 inches lower than your eye at the viewfinder. Close up , that can mean 2 inches of missing subject matter in the picture - unless you use the marks.
Most Leica bright-line finders use similar marks (e.g. my 21 and 28 finders)
Yes, I do not ask what kind of lens you are planning to use, in my mind I was thinking about a 90mm.
