fw 2.002
Knorp
Simple fix to having the numbers reset when you do a firmware upgrade.
Take a card and take a shot. Take that card out and use another card to do the FW update. After the FW update is done and you have turned the camera off take the card out you use to do the update and insert the one you just took one image with. Turn the camera on and VIEW/PLAY that one image on the cameras LCD screen. Hit the info button to view the number on that image. Take one more shot, hit the play then the info button to view the number of the new image you just took (it shouyld be the next number after the one that was on the card), format the card in the camera. Your numbering well continue from that number on.
This can happen anytime. Say I had a card I hadn't used in several months and it had images left on it and the last image was numbered L1004678 and the camera was now recording images in the L1008xxx range. If I stuck that card in the camera and VIEWED the images on that card the camera would remember the last image number taken on that card and start numbering images from that last image number.
Even if you don't have an image saved on a card to do this with, you can just shoot a DNG, download it and re-number it manually to what you want it to be, then put it back on the card and follow the above procedure.
x
  • Replies 48
  • Created
  • Last Reply
Has anyone else noticed improved Auto White Balance in this firmware upgrade coming from the 2.0 firmware? Or am I just imagining it?
Actually, I noticed the opposite. Mine had been great but was completely messed up after the update, so I did a re-install and it now seems like it was previously.
So, can someone actually confirm that the update works with an SDHC card if you already have v2.0? I have an M8.2 (i.e. firmware version is 2.0) and I don't even have an SD card. I don't really want to buy one just for this update... :p
Thanks,
Edi.
SDHC does work if going from v2.0. I read somewhere that it would, and yes indeed it does. I used a Sandisk 4GB SDHC card and it worked.
This is why you might want to upgrade:
“Bug Fixes“:
a. If LEICA M8.2 cameras are set to the “Discreet” option and to single exposures, an unintended “black image” may have occurred when the finger was not completely lifted from shutter release button before pressing it down again for the next shot. (Not valid for LEICA M8 Cameras)
b. Setting “AUTO-ISO” in combination with lens dependent setting of the slowest shutter speed: the camera will switch to the higher ISO when the shutter speed corresponding to “1/focal length” is reached (was 1/focal length + 1 f-stop).
c. Correct display of image numbering.
d. Correct display of the fastest sync speed in the menu (1/180s on upgraded M8 and M8.2, 1/250s on M8).
My free service to you :D
Kind regards.
Jaap,
I have V2 installed, and have no intention of buying the new lenses. I don't use Auto ISO either. I'm in fact very happy with the performance of the camera, as is.
Normally, I upgrade all cameras immediately after a FW is released. Not this time, because I was feeling that I already had the ultimate performance from this camera. So I'm hesitant to reverse anything from this performance level.
Do you think that there may be some unannounced improvements in the new file, that you may still recommend an upgrade?
Seyhun
Yes
usually when i upgrade firmeware I get something that opens and gives me 2 icons as shown on Leica. Now I get this:
I do not want to mess up my card or camera.
Caryl
