Help please engraving on Summar
I have recently purchased an uncoated collapsible Summar 5cm F2 for a project I have in mind. Being new to these older lenses, this is serial 217254, I don't know if this is usual. There is a letter A engraved on the rear of the infinity lock. Is this "normal" and does it signify anything ?
Curios... I checked mine (248306) and it halso has a letter engraved in the same place (lock looks identical to yours)... but it's a "B", and I never noticed it...:o ... Summar rectractable is considered such a common lens that I never inspected it with attention. One possibility that comes to my mind : my item has the scale in feet... is it yours scaled in meters ? If so, could be a sort of identifier for the department that made the scale engraving... could have a sense, imho, given a certain workflow organization in the assembly/machining line.
Normally all of the screw mount lenses with infinity locks are stamped with a code. I believe these codes signify the exact focal length of the lens so the lens components can be matched during the manufacturing process. M lenses are also coded with a small number located after infinity mark and meter M on the focus ring.
Some lenses not marked in either place may be marked with a number scratched inside the lens barrel.
Len
Len
Yes, can be the other reasonable explanation... such identifiers are sometimes "hidden" (like the ones roughly hand-engraved in the mounts) sometimes evident (like, for instance, the "19" after the "m" symbol in the scale of my Summicron 50); I hope some poster will tell us which letter they find on their Summars... many forum members have one.
Mine have a "00" or is it a 8 or a B ?
I guess it's zero-zero.
... smells like mine... I said it's a "B" , but mainly for Chris' one has surely an "A".. :o : my engraving could indeed be an 8 or even two "o" superposed... what is number and distance scale of yours ? Well... maybe I'll make a quick pic of mine...
Scale in Meters, s/n 256509 = 1935.
Cheers
OK, meters and "B" or "8" or whathellitis... my hypotesis proves wrong... And Len is probably right. Another hypotesis that came to my mind was that the "A" could have some relation with a factory modification of the lens... Leiz offered a service to convert rigid Summars in retractable... but the s/n of Chris' item seems too high for a "converted rigid".
Ha ha I just look at an Elmar RS it wear a 9 !
Have to check the others...
And MY Elmar RS has a 7, always under the lock !!! Damn... > 20 years with these lenses and, wouldn't it be for Chris, I would never noticed these tiny engravings... really, there is always something to learn, in the Leica world...:)... thank you, Chris !!!
I noticed this numbers long time ago as I make a CLA to this lenses but do not pay more attention about their significative.
My guess was that it was the "vertical 8" for infinity, but i never happened to see the meaning of putting this sign below the lock. Both my Summar (No. 3244xx) and Summitar (No. 5232xx) have it, both have the meter-scale. On postwar 50-Elmars (bayonet) i can't find anything similar.
