M3 focus spot high in the viewfinder
Chrishayton
Hi. Ive just recieved my first leica M camera and its great except the focus patch is not quite centered. Its centered horizontally but not vertically. Its a little high when looking
compared to the frame lines ( most noticable on smallest set)
Its not out by much and doest proceed past the top of the | | bits of the guidelines.
Is this normal??
__...............................__
|...........|_______|............|
|_................................._|
^ example diagram.
It isn't an uncommon issue. I had this on my first M, an M4-P. It shouldn't affect focusing, to me it was just incredibly annoying. The vertical alignment can be adjusted if you're game. Here is a howto: Leica FAQ - DIY rangefinder adjustment
- Carl
The way I read it this is not what was meant, its the position of the rangefinder patch that is not centred rather than the vertical alignment of the two images.
I have just looked at my M3, the patch is quite a bit above centre, very obvious if the 135 frame is selected, I have never noticed it before in 40 years of using the camera, I presume its normal, all seems to be working anyway. :)
Gerry
The patch lines up with the seperate image, its just the patch is nearer the top of the frame than the bottom. Is this the same issue to correct
Edit
Ah great. Yes thats what i ment ( to the second poster) so this is normal then? hope so as the camera is fantastic
As I said above, I think its normal, maybe others can confirm, I only have one M3!
Correction, if necessary would be a strip down and reassembly of the rangefinder, a pretty skilled job
Gerry
Don't have my M3 anymore, but can confirm that the rangefinder patch is not perfectly centered along the vertical axis. It does sit a little higher and it is mostly noticeable when the 135mm frame is engaged.
Nothing to worry about......
Best,
Jan
I've just checked my M2, it appears ever so slightly towards the upper half of the frame lines (don't forget the patch and framelines move as you focus for parralax correction). I folded a piece of paper to use as a guide, framed it and yes it is just off centre.
I've not noticed it before now - it would appear to be how they are designed.
