Leica M3 top speeds
timetraveller
Hi,
I've got a Leica M3 which has the top speeds (1/500 and 1/1000) a little bit off by 1/2 stop and 1 whole stop.
The strange thing is that at these speeds, negatives come out with less density that they should...usually, at top speeds, other cameras fails,and negatives come out with more density, which means that shutter is slower that it should at that speed.
With this Leica, is the opposite, shutter is FASTER that it shoulds...
Have you experienced this with your cameras???
Thank you
x
I have adjusted several M3 shutters and one M4-P for my own use and my experience is
as follows: in general shutters work quite well after a CLA but the fast times(500/1000)
need adjustment due to capping. I never had it the other way round so I definitely believe
your M3 is ready for a CLA. Many people believe it´s not possible to adjust older Leica
shutters to give even exposures, from my own experience I don´t believe this but it takes
a lot of time, try and error to get to near perfection.
I always try my shutters with slide film, colour neg is the wrong way(to me).
Jo
Jo
I try it with b&w negative and a densitometer. I do reciprocity test to be able to compare with other speeds. same EV at different apertures and speeds, same (theoric) density.
Jo
Sorry I don't understand rhe word "capping", it means tha the shutter "sticks"??
On the other hand, haw do you adjust the shutter?Maybe with the little screw in the speed's dial?
Thank you
Here is an example of what I get with my M4-P at 1/1000. You can notice the underexposure and a darker zone at the left. Maybe it should be better to join this pic when I'll send my camera to Solms?
Hi,
Thank you
As I said in another thread a little while ago, this happened to my M3 after a while and the Leica technician who tested the shutter (at an open day) said it was typical of a shutter that needed cleaning and adjusting.
Gerry
The M3 top speeds can only be adjusted after lifting off the top cover, provided the tension
on the take up drums is ok. The little screw in the speed dial has nothing to do with that.
You need special tools plus manual(s) plus a lot of time for try and error if you want to do
it DIY.
Basically I think one can´t expect a 50 year old camera to be in perfect working order so
you have to spend a considerable amount of money for a profeesional CLA but it´s well
spend money.
Jo
Capping normally means the second shutter blind is catching up with the first, a reason for
uneven exposed shots like the one above. An easy solution could be to give more tension
on the first shutterblind but that´s bloody wrong.
The camera needs a CLA and only after that one might start playing around a little bit with
the tension.
Jo
spend money.
Jo
It depends upon whether you consider about £150 a "considerable amount of money"
Useful insights on this thread. I recently starting using a M3 that had been in a box for ~20 years, and I think it may be suffering from a similar problem at higher shutter speeds.
I think I need to burn a roll of film and do some detailed exposure testing...
Well, it depends on you personal situation but I think GBP 150 is a fair amount for a M3
CLA. Don´t forget, after that you have a more(internally) or less(externally) new camera
that will give good service for a very long time when all the Chinese plastic chunk will have
gone into the bin since long...
Jo
Thank you, James. Unfortunately, we don't have local repairer here in Belgium. Maybe if I go to Paris I will spare money. Or somewhere in Holland. Any tips?
index.html Will van Manen Kamera Service in Holland.
Highly recommended and his prices are reasonable
I heard cameras and watches suffer more, if their mechanics does not move. I got the advice to use all shutter speeds occasionally if the camera is stored. This might go back to the time, when lubricants were not synthetic yet, hence the risk of resinifying might be lower with modern watches and cameras.
Maybe it is just an excuse to play with the M3 from time to time ;)
Stefan
I have a mint M3 that had not been used for decades, grease was gummed up, long times
not working anymore. After some hours I solved this and now I have a perfectly working camera again. How could I expect to buy a camera in perfect working order. Btw, all oil
and grease I applied is synthetic.
Jo
