leicanet Posted July 3, 2008 Share #1 Posted July 3, 2008 Advertisement (gone after registration) Greetings to all... yes, I have eventually got got hold of a R9... and I am about to get what it is, from the many reviews and comments I read, the lens that is considered to be one of the best all purpose (but especially macro) lenses available for the R system, the APO Elmarit-R 100/2.8 ROM. Now, I am deciding between which attachment/extension to go for 1.1 macro work. Should I go for the Macro Adapter R 14299 or for the Elpro 1:2-1-1? And what would be the main pros/differences between the two? Many thanks in advance for your invaluable advice! Link to post Share on other sites More sharing options...
Advertisement Posted July 3, 2008 Posted July 3, 2008 Hi leicanet, Take a look here Macro work on a APO Elmarit-R 100/2.8 ROM: Elpro 1:1 or Macro Adapter R 14299?. I'm sure you'll find what you were looking for!
dritz Posted July 3, 2008 Share #2 Posted July 3, 2008 Absolutely go for the ELPRO designed for that specific lens. One you see the gorgeous rendition of transitions in color and tone in the 1:1 reproductions, you'll be hooked. Shoot slide film with it (don't use saturated films) and have a slideshow party. Link to post Share on other sites More sharing options...
leicanet Posted July 3, 2008 Author Share #3 Posted July 3, 2008 Dritz, thanks for your reply. The thing is I have found a Macro Adapter R 14299 to go with the lens, about £195 brand new (list here in the UK is £495), and I am tempted to go for it, considering also the difference in price (and availability) with the Elpro 1:2/1-1, well more expensive. Could you/anybody tell me the real term differences between using that and the Elpro? Thanks! PS One day (one day but who knows when...) I will also get a DMR... Link to post Share on other sites More sharing options...
kajuku Posted July 3, 2008 Share #4 Posted July 3, 2008 Having just sold my R9/DMR to a member of this forum, I am about to post an offering of my R glass in buy and sell. Among the items to be sold is the APO Elmarit 100/2.8 (3-cam) with the Elpro. In my experience, the lack ROM is no hindrance for this setup. If someone here is interested, PM or email me. Jonathan __________________ jonathanreissphotography.com Link to post Share on other sites More sharing options...
ejd Posted July 3, 2008 Share #5 Posted July 3, 2008 The reason for using the elpro and not the macro adapter is that the rear two elements of the apo macro elmarit are fixed and do not move when the lens is focused. They are intended to be precisely the distance they are from the film plane. They are there, I believe. to improve the close-up performance of the lens. If you use the macro adapter, the rear elements are moved further away from the film plane, and the image quality is not as good. Using the elpro leaves them where they were intended to be. I'm not sure you'd have to pay more for a used elpro than for a macro adapter. I've seen the elpro around for between 99 and 199 pounds (and you can pay more, of course). The alternative to the elpro might be the 2x apo-extender, which gives you a 200 mm f 5.6 lens and 1:1 reproduction ratio, but you would then get a dimmer image in the viewfinder. And also the extender is more expensive. One small drawback of the elpro might be that it shortens the effective focal length of the length of the lens, so you do not get the relatively long camera-to-object distances at 1:1 that you would get with an actual 100mm focal length lens. I think it becomes more like a 70mm lens. And then it sounds not too different from the 60 mm macro elmarit. This may or may not matter. Rgds, John Link to post Share on other sites More sharing options...
masjah Posted July 5, 2008 Share #6 Posted July 5, 2008 The Macro Adapter (and other extension rings for that matter) should not be used with this lens. The dedicated Elpro is specifically computed for it, and is the preferred option. Link to post Share on other sites More sharing options...
ho_co Posted July 5, 2008 Share #7 Posted July 5, 2008 Advertisement (gone after registration) Remember also that the macro adapter is just an extension tube. As such, it reduces the effective aperture of the lens. That is, by putting the lens further from the film, you make the light travel further; and that means (inverse-square law) that less light gets to the same surface. With the Elpro, you maintain both the lens's speed and optical correction. Using the Macro-Adapter-R with the 100 APO would be like putting retreads on a Ferrari. 1 Link to post Share on other sites More sharing options...
trickness Posted April 1, 2024 Share #8 Posted April 1, 2024 Holy necro-thread! Looking at the Elpro for the 100 2.8 now and yikes, it's at least $400 for a decent one.... 1 Link to post Share on other sites More sharing options...
darylgo Posted August 15, 2024 Share #9 Posted August 15, 2024 On 4/1/2024 at 4:55 PM, trickness said: Holy necro-thread! Looking at the Elpro for the 100 2.8 now and yikes, it's at least $400 for a decent one.... Were you able to find one? The only options I see for the Elpro are $600-$700 on ebay. The non rom macro adapters are $50, certainly worth a try, alternatively the 2x Apo would also get to 1:1 or thereabouts. 1 Link to post Share on other sites More sharing options...
trickness Posted August 16, 2024 Share #10 Posted August 16, 2024 22 hours ago, darylgo said: Were you able to find one? The only options I see for the Elpro are $600-$700 on ebay. The non rom macro adapters are $50, certainly worth a try, alternatively the 2x Apo would also get to 1:1 or thereabouts. I did, from Japan, close to $600 in the original box. Crazy. Haven’t really used it, can only imagine what these will cost in five years. Link to post Share on other sites More sharing options...
LocalHero1953 Posted August 16, 2024 Share #11 Posted August 16, 2024 Does no one look at the classifieds here on the forum? I had a 100/2.8R and Elpro listed there for a month with no takers. 😒 1 Link to post Share on other sites More sharing options...
darylgo Posted August 16, 2024 Share #12 Posted August 16, 2024 46 minutes ago, trickness said: I did, from Japan, close to $600 in the original box. Crazy. Haven’t really used it, can only imagine what these will cost in five years. After a long search I did find one at Leica Store Miami at a good price. It's complete except for the rear cap and box. 33 minutes ago, LocalHero1953 said: Does no one look at the classifieds here on the forum? I had a 100/2.8R and Elpro listed there for a month with no takers. 😒 I put one item for sale on the forum classifieds, didn't get a single inquiry, and of course I never look there either, the thought never crosses my mind. The few times I looked have been less than inspiring. Link to post Share on other sites More sharing options...
trickness Posted August 16, 2024 Share #13 Posted August 16, 2024 1 hour ago, LocalHero1953 said: Does no one look at the classifieds here on the forum? I had a 100/2.8R and Elpro listed there for a month with no takers. 😒 I never ever look there. Guess I should! Was your 100 a ROM lens by any chance? Link to post Share on other sites More sharing options...
LocalHero1953 Posted August 16, 2024 Share #14 Posted August 16, 2024 10 minutes ago, trickness said: I never ever look there. Guess I should! Was your 100 a ROM lens by any chance? I can’t remember offhand, and I’m away from it at the moment. It was not of relevance to me as I used it on the SL2-S. I’ll check when I’m home in a week or so. Link to post Share on other sites More sharing options...
trickness Posted August 16, 2024 Share #15 Posted August 16, 2024 2 hours ago, LocalHero1953 said: I can’t remember offhand, and I’m away from it at the moment. It was not of relevance to me as I used it on the SL2-S. I’ll check when I’m home in a week or so. Nice thing about the ROM version is the SL2 recognizes the lens Link to post Share on other sites More sharing options...
LocalHero1953 Posted August 17, 2024 Share #16 Posted August 17, 2024 8 hours ago, trickness said: Nice thing about the ROM version is the SL2 recognizes the lens Perhaps that is what I have - the SL2-S recognises it. Link to post Share on other sites More sharing options...
