Annibale G. Posted April 13, 2008 Share #1 Posted April 13, 2008 Advertisement (gone after registration) Usually I'm shooting in interior , very high contrast, low light condition. I was thinking about to buy a flah unit to use as fill in flash. I've seen from Leica catalouge that there is no more the sf20; is it discontinued? What are the difference with the sf24D? What about buying a used Sf20? Annibale Link to post Share on other sites More sharing options...
Advertisement Posted April 13, 2008 Posted April 13, 2008 Hi Annibale G., Take a look here SF20 and SF24D . I'm sure you'll find what you were looking for!
budrichard Posted April 14, 2008 Share #2 Posted April 14, 2008 I have the SF24D, my understanding is that in non-TTL mode it offers more f-stop settings than the SF20 but if you have TTL it should function the same. This reference has a pretty good discussion. Photoethnography.com - Classic Cameras -Dick Link to post Share on other sites More sharing options...
Annibale G. Posted April 14, 2008 Author Share #3 Posted April 14, 2008 so... what's should be the better chose to use only for fill in ? Link to post Share on other sites More sharing options...
j. white Posted April 14, 2008 Share #4 Posted April 14, 2008 I own the SF-20 and find it exceedingly useful for fill-flash. They can be found for very reasonable prices these days as well. I have a question regarding the two: Is the SF-20 fully compatible with the M7 and M8 in TTL mode? I have not been able to find a definitive answer in the standard literature. Thanks, -J.. Link to post Share on other sites More sharing options...
LeonardT Posted April 15, 2008 Share #5 Posted April 15, 2008 I own the SF-20 and find it exceedingly useful for fill-flash. They can be found for very reasonable prices these days as well. I have a question regarding the two: Is the SF-20 fully compatible with the M7 and M8 in TTL mode? I have not been able to find a definitive answer in the standard literature. Thanks, -J.. The SF20 is not compatible with the M8 in TTL mode, only the M6TTL and the M7. The SF24d is compatible with all of them. You can use the SF20 and M8 in A mode though. Len Link to post Share on other sites More sharing options...
masjah Posted April 15, 2008 Share #6 Posted April 15, 2008 The SF20 is not compatible with the M8 in TTL mode, only the M6TTL and the M7. The SF24d is compatible with all of them. You can use the SF20 and M8 in A mode though. Len Yes, the SF20 does not support the Leica digital "pseudo-TTL GNC", whereas the SF24D does. I have a Leica CL, which, although a film camera, also utilises "GNC" together with an SF20. The two work well together in A mode; indeed, the working aperture IS correctly transmitted by the camera to the flash, which is nice. Several Forum members consider the "GNC" mode to be a bit of a pain anyway, and actually prefer the A mode. Link to post Share on other sites More sharing options...
Annibale G. Posted April 15, 2008 Author Share #7 Posted April 15, 2008 Advertisement (gone after registration) will be good the Sf 20 for M7 in all useful mode ? I'm new with the flash Link to post Share on other sites More sharing options...
Tom Johnston Posted April 15, 2008 Share #8 Posted April 15, 2008 i have the sf20 for my m7 and it works quite nicely for a small flash unit. i use the nikon cord with it for taking it off camera. i use it in ttl mode, yes. i've been reading about trigger voltages and haven't found what it is for the sf20 - does anyone know this information? Link to post Share on other sites More sharing options...
Annibale G. Posted April 15, 2008 Author Share #9 Posted April 15, 2008 A dealer sell the sf20 at 200€ . Should I buy it for what I need? Can I use it in manual exposure mode? Can't I use all exposure time? What mainly have the sf24d respect to the sf20? Annibale Link to post Share on other sites More sharing options...
masjah Posted April 15, 2008 Share #10 Posted April 15, 2008 Oops! I meant to say "CM" not "CL"! (Let the Freudians make of that slip what they will.) Link to post Share on other sites More sharing options...
masjah Posted April 15, 2008 Share #11 Posted April 15, 2008 A dealer sell the sf20 at 200€ . Should I buy it for what I need? Can I use it in manual exposure mode? Can't I use all exposure time?What mainly have the sf24d respect to the sf20? Annibale I think that 200€ for and SF20 is far too much. Presumably this is second-hand (even if not, the price ought to be close to the second hand price, since it is superseded by the SF24D) and they go in the UK for about £90. Link to post Share on other sites More sharing options...
Guest Bastian A. Posted April 15, 2008 Share #12 Posted April 15, 2008 200 € is too much for the SF-20! I bought one for 70 € recently (Ebay) but that was very cheap. About 120 € seems to be a normal price. B. Link to post Share on other sites More sharing options...
Annibale G. Posted April 15, 2008 Author Share #13 Posted April 15, 2008 But does it works in manual exposure mode at all exposure times? As a fill in should I take exposure in the background use these time and aperture, compensate -1 stop the flash and shot? Link to post Share on other sites More sharing options...
dfbldwn Posted April 15, 2008 Share #14 Posted April 15, 2008 My 24D works in manual mode at shutter speeds of 1/50 or slower with my M7. With my M6, I can get 1/60th shutter speed to work 99% of the time, otherwise same as M7. With M7, I find A mode more useful than TTL mode, particularly when shooting Kodachrome. In sunlight or open shade, the "A" mode provides nice fill flash effect when set at normal shooting speed for the film I use. So I have never applied an f-stop compensation when using it as fill flash. Am currently using M mode because of problems with deep background causing flash in A mode to overexpose. Main difference I can tell between 20D and 24D is that the 24D has a cheap plastic diffuser which one clips onto front of flash if using focal lengths greater than or equal to 85mm. It "focuses" the flash so that it is actually stronger, so use the higher guide number. I have not found the 24D to be the most consistent flash unit I have ever owned. I still use it due to portability. Also, I got sensitive about the ladies angrily shouting "Jesus David!" at the church suppers when I used a Vivitar 283 (excellent unit, but just too bright, even for hard- boiled Georgia Baptists who've seen everything). Link to post Share on other sites More sharing options...
Annibale G. Posted April 15, 2008 Author Share #15 Posted April 15, 2008 I really don't know which is good for me? I even don't know if it is for what I need. A. Link to post Share on other sites More sharing options...
pleeson Posted April 16, 2008 Share #16 Posted April 16, 2008 I recently sold a mint condition SF20 for $88. Don't pay too much. I'd buy a used one, to try it out -- I'd bet you rarely use it. I had mine for 5 years and never used it once... Link to post Share on other sites More sharing options...
Annibale G. Posted April 16, 2008 Author Share #17 Posted April 16, 2008 But will be good as a fill in flash? Link to post Share on other sites More sharing options...
budrichard Posted April 16, 2008 Share #18 Posted April 16, 2008 Purchase an SF 24D, which will suffice for any compatability issues.-Dick Link to post Share on other sites More sharing options...
wiedemann Posted April 26, 2008 Share #19 Posted April 26, 2008 Here you'll find a suggestion how to use the SF24D with the Visoflex III http://www.l-camera-forum.com/leica-forum/forum-zur-leica-m8/51187-m8-und-blitz.html#post539049 Wolfgang Link to post Share on other sites More sharing options...
Tom Johnston Posted April 27, 2008 Share #20 Posted April 27, 2008 I wrote to Leica Tech. Services in NJ about the trigger voltages of the SF20 & SF24. They replied: "The trigger voltage for the Leica flash units is under 6 volts, which should pose no danger at all to digital cameras." Link to post Share on other sites More sharing options...
