28mm-R/2.8 needs lubricating
symmetron
Tried once with a R24/2.8 with no avail. Removing the bayonet is not complicated per se but the helicoidal ramp is not visible yet, there are other parts to remove afterwards like the f-stop preselection ring so i dared not go that far.
Joseph
Hope you don't mind my saying that your post rang alarm bells for me! Assuming that you have the tools and knowldege to dismantle to the point of exposing the helicoid threads (both threads, inside and outside that is) you really would need to clean out and remove the old dried out lubricant first of all. So I would have thought that it would be very important also to know what the appropriate solvent is. Then, with the lens partially dismantled, there would be the danger of getting solvent, old gunk and new lubricant on the optical surfaces, possible including internal ones. The more I think about it, the less I personally feel I would have the nerve to do it. I really would send it in. Hope you don't mind my being frank!
