M coder kit
jc_braconi
x
I've had the coder about a week now, and am having trouble coding my 24 Elmarit and 90 Elmarit. I've tried several times, but the camera doesn't recognize either one. I'm not giving up, because so many have had success with the kit, but I'm wondering what my problem is....anyone else had trouble, but then found some answer? I follow the directions exactly, the dots look right, I use the pen included in the kit...no luck. The camera does correctly identify my officially Leica-coded lenses, so I know the problem isn't in the camera.
Curt
Curt
I had some problems with the kit and found when I put the coder ring on my 28 mm Elmarit -M that only half of the black dots showed through the holes. There is presumably some variation in the production. i however think Tim is sending me a new ring. But I modified mine until the holes corresponded with the spots on the 28 and after that I could code all my other lenses.
So get hold of a factory coded lens, try your coder on it and see if it is correctly aligned.
Great idea....thanks, I'll try it.
After how many mountings/unmountings does the coding erase ?
Is there a way to avoid this with some permanent ink marking
(kind of serigraphy) ?
Yesterday Dirk A. contacted me after receiving my Coder Kit. He used a burring tool found in dentistry. Because of his practice with this burring tool he was able to texture the surface of his lens base in the positions corresponding to the required encoding marks. After texturing he applied the ink using the M-Coder. He claims this formed a very durable mark on the lens that does not wear off. One can think of the texturing as a sort of micro pocket for the encoding marks. All of his lenses were encoded successfully using this technique.
There is a very serious nature to this procedure. That is the use of the burring tool, which may turn at 10,000 rpm, and could easily get out of hand and 'walk' across the lens mount surface in places you don't want it to go! Also, there are the metal fragments that can become airborne and can find their way everywhere. If this technique is carefully practiced with great care and in skilled hands, it can certainly improve the durability of the encoding marks.
Here is a photo he sent me of the burring tool. it may be about 20mm in length, or smaller. I do not have a sense of the scale of it yet. He may have even used it through the openings of the M-Coder. I will ask about those details and post here again.
JC--
My experience with the coder kit has been excellent all around. First, the kit is nicely finished and packaged, and it works precisely as intended. The temporary self-coding will wear after several lens changes [8-10 or so, in my case], but generally only some of the pigment is removed, so that I can still see the location of the marks on the flange, and use a sharpie marker that I keep in a side pocket of my Domke bag to darken the marks, when needed [if I'm out shooting, I'll usually check the lenses before I go out]. I really have not had the camera fail to recognize the lens that is on, as marked.
As for the the transaction, it couldn't really be easier or more pleasant. Communication is excellent, shipping rapid, and packaging fine. I've now gotten a Thumbs Up Model 1 and the Coder kit from Tim, and just ordered the Thumbs up w/ cold shoe for my other M8.
Norm
Hmm, I just might try something similar on one of my LTM-M adapters to see how it holds up. As it would be on a loose adapter there is much less risk involved.
- Carl
I'm very interested by this product but I'd like to know if the M-Coder works fine with the CV Skopar 21 and Superwide 15 ?
Thanks for your help.
François
Oui François, ça marche très bien avec le CV Skopar 21. Yes, it works very well with CV Skopar 21 but not with the Planar 50/2 due to the screw at wrong place. CornerFix considers this lens as a Summilux 50/1.4 instead of Summicron 50/2.
4 days from order to delivery.
Michel
  • 2 years later...
