New: Firmware Update v.4.0 for Leica SL3 / SL3-S
3 hours ago, mirrorless said:
I wonder what the difference is between Person (Eye/Face/Body) and Person (Eye/Face) Obviously with the first option the body is being recognized in addition, but when should you choose only Eye/Face?
Also is it only me but after the firmware update the Eye-AF works only when the face is quite in the middle of the frame. When pointing on a person that is located in the left or right third area of the frame there is no recognition. Was that before? This is happening in both modes. Field/Spot and Zone.
Some initial thoughts, I see potential advantage between prioritizing Eye/Face/Body vs just Eye/Face, YMMV:
-Eye/Face/Body could be optimal for person/people in motion. E.g., live performances, dancing, sports, large crowds, wildlife etc.
-Eye/Face might be optimal for instance portrait, headshots etc.
Also, I see active human and animal eye recognition all the way out to the edges of the frame. Do experiment with the difference AF modes to include resizing the area of AF via the AF Quick Setting as noted above.
*I'm currently experimenting, exploring, discovering, learning v4.0 AF/AI with the SL3 and the SL 90 APO.
Edited by LBJ2
I already mentioned how impressed I was with the quality and ease of use of the Multishot mode recently introduced on the SL3.
I'm sharing a few examples with you, without any aesthetic pretensions; these are simply a few test shots.
Configuration: Leica SL3 + Leica APO-SUMMICRON-SL 1:2/35 ASPH.
Image size 19040 x 1272 — 262 MB
Image of the sofa: distance 4 m.
Photo of the clock tower at Colmar train station: distance 113 m.
Of course, the photos in the appendix are offered in a much lower resolution, but probably sufficient to support my point.
Best regards,
  • Thanks 2
2 hours ago, SoarFM said:
I also agree that this is undesired behavior. I don't know if it's a bug or intentional. But I'd like it to do standard object tracking if it can't detect any human or animal.
It seems like a bug, though I can’t imagine how they wouldn’t have been aware of it.
The other modes (field/spot, zone/multi-field) behave normally with detection on and no human or animal in the focus area.
On 12/19/2025 at 6:57 AM, carlosgavina said:
I've only tested this so far very briefly around the house (with subject detection on and off).
I think the change in the AF is definitely in the right direction, way more stickier, separating the modes and subject detection makes sense to me as I described on another post, and it covers many of my main complaints about it! So congrats and thanks to the Leica team!
However I do see some quirks/bugs still.
Tracking mode makes much more sense now, then toggling on/off the subject detection seems promising, however, there seems to be a bug/quirk:
- I I select tracking mode
- If I have subject detection off. Everything works great, I hold the shutter button, starts tracking whatever was behind the tracking indicator, take the photo, if I stop holding the shutter button the indicator returns to its initial location.
- BUT, if I turn subject detection on, the tracking just stops working if there's no subject in the frame. It becomes "useless" and works a bit more like the other modes where it only focus on anything on its initial position, no tracking. Only when a subject overlaps the indicator location, kicks in the tracking to the subject. I was expecting for the tracking to work the same if there's no subject detection in frame.
On the Nikon Z8, in their 3D tracking mode, you have the square tracking indicator (that can be moved), and if subject detection is on, but no subject is in frame, it just defaults to normal tracking whatever there was behind the indicator when you hold the shutter button. I think this makes a lot of sense to me. I believe it's similar to what the Sigma BF does as well.
This way it would make it even less frequent to have to toggle modes/subjects. Not sure how others do, but I do like to be intentional in "locking" into a subject, then press and hold the shutter button to "track" a subject, then recompose and shoot.
Small quirks but this is to me already a big improvement both in AF stickiness and UI. And I love the multi shot mode on the SL3 too 👏
I second @FlashGordonPhotography, we just need EFCS so I can use the 90-280 without having to resort to the electronic shutter or super high shutter speeds.
You wrote:
"- I select tracking mode
- BUT, if I turn subject detection on, the tracking just stops working if there's no subject in the frame. It becomes "useless" and works a bit more like the other modes where it only focus on anything on its initial position, no tracking. Only when a subject overlaps the indicator location, kicks in the tracking to the subject. I was expecting for the tracking to work the same if there's no subject detection in frame."
I tried to replicate with the SL3+SL 90 APO but had different results: ( If I understand your process correctly):
1. Selected tracking mode
2. Selected AF Detection OFF
3. Pressed the shutter button and started tracking whatever was behind the tracking indicator. Just as you described. ( Subject used = man's face with specs)
4. With the camera in tracking mode and the same subject, I selected AF Detection from OFF to Human Eye/Face and the human eye/face recognition kicked in and tracked as expected. *** I noticed w/both AFS and AFC and in Tracking mode I was not able to manually toggle the EYE indicators( little boxes) from one eye to the other--seems the camera decides which eye while in Tracking mode.
Did I replicate your process correctly?
Edited by LBJ2
The issue is:
Eye/Face ON
Tracking ON
If there is no eye or face, the camera won’t track anything.
Expected result would be if there is no eye or face under the AF tracking field, track whatever is under the field.
This is how the non tracking modes work.
Edited by LD_50
10 minutes ago, LD_50 said:
The issue is:
Eye/Face ON
Tracking ON
I agree - this looks like a bug, or a poorly thought through design. My current preference is to use Zone and Body, but if I want to change Zone to Tracking, I have to make two changes: Zone to Track and AF Detection to Off. I can't believe this is intentional.
25 minutes ago, LD_50 said:
The issue is:
Eye/Face ON
Tracking ON
In firmware 4.0 on Q3 43, this behavior is just as strange. It's unclear what the developers were thinking behind this decision.
1 hour ago, LD_50 said:
The issue is:
Eye/Face ON
Yes. With Eye/Face ON and Tracking ON, if there is no face or eye in the frame tracking does not appear to be active. However, if we turn OFF, AF Detection then tracking engages with various subjects. For now, if someone wants to track something other than face/eyes/body, turn OFF AF Detection.
I don't know if this is a bug or intentional somewhat awkward design--particularly as there is no ver 4.0 AF guide or other explanations in the firmware notes. But as you mentioned it and I also confirmed, now I know if I want track anything other than humans or animals, I need to turn off AF Detection.
*Note to Leica
Edit, I seem to be able to track animals in general with Animal AF Detection On or Off while in Tracking mode.
Edited by LBJ2
I note that switching to Multi-Shot mode automatically engages the self timer. There does not seem to be an option to  turn it off for hand-held shooting (admittedly something I'd rarely do). Am I missing something?
And Season's Greetings to all the participants who are so helpful in this forum.
Glad to see this update and MS. I had hoped for focus bracketing to be added also. As for EFC I believe the shutter in the camera for some reason cannot support it. Leica has never had this available and it really needed with long glass especially in portrait mode. Just should not be that hard to add.  Happy to see one out of three needed features added. I will also add that if you are willing to down sample the MS to 100MP resolution many times the results are excellent.
Paul
Paul
Isn't that always the case?
