2Rocky Posted 10 hours ago Share #1 Posted 10 hours ago Advertisement (gone after registration) Hi, I am in the process of purchasing this Leica Summarit 50mm 1.5 lens for my M11.. When I fit the lens to the body, go to manual lens set up and set 50 f/1.4 11868/11856/11114 The LV goes dark but hen I 1/2 press the shutter button, the ASA, Shutter speed all come up on a dark screen.. Is this lens with it's adapter compatible with the M11... Any advice welcomed as I have kept this lens for many years and wish to use it for it's special properties. Link to post Share on other sites More sharing options...
Advertisement Posted 10 hours ago Posted 10 hours ago Hi 2Rocky, Take a look here Leica Summarit 50mm 1.5 on Leica M 11 M. I'm sure you'll find what you were looking for!
romanus53 Posted 9 hours ago Share #2 Posted 9 hours ago using old lenses with adapter is no problem, try to set lens detection off, try an other adapter if possible, if using EVF check correct position Link to post Share on other sites More sharing options...
lct Posted 7 hours ago Share #3 Posted 7 hours ago You may wish to try Dust Protection Off. Did work there: Link to post Share on other sites More sharing options...
2Rocky Posted 6 hours ago Author Share #4 Posted 6 hours ago 3 hours ago, romanus53 said: using old lenses with adapter is no problem, try to set lens detection off, try an other adapter if possible, if using EVF check correct position Hi Many thanks for the advice, the adapter came with the lens, so I will try another. Do you know of any recommended adapters? Evf is in correct position. Link to post Share on other sites More sharing options...
2Rocky Posted 6 hours ago Author Share #5 Posted 6 hours ago Thanks for the advice, will try that as well.. Best Link to post Share on other sites More sharing options...
lct Posted 6 hours ago Share #6 Posted 6 hours ago (edited) 7 minutes ago, 2Rocky said: you know of any recommended adapters The 6bit coded Kipon 50.75 # 004071 works well with my Summicron 50/2 collapsible. You may wish to pen code it as Summilux 50/1.4 pre-asph that vignettes more or less the same way as the Summarit 50/1.5. Edited 6 hours ago by lct Link to post Share on other sites More sharing options...
2Rocky Posted 2 hours ago Author Share #7 Posted 2 hours ago Advertisement (gone after registration) Hi, Many thanks for your suggested adapter... I will try it if all the other suggestions are not successful.. Best Link to post Share on other sites More sharing options...
2Rocky Posted 1 hour ago Author Share #8 Posted 1 hour ago Dust protection worked ... Many thanks to all the other members who contributed 1 Link to post Share on other sites More sharing options...
