Just photographed a Labor Day Parade in town, a good experience. I used both my CL and M8, the M8 had a 75mm Voightlander on it, I have used this combination quite a bit and had no problems until today. In the meat of the parade the camera didn't record the images. On the SD card the numbering goes from xxx7740 then jumps to xxx7750, none images in the 40's is there or recorded. I changed the lens near the end of the parade and all those images are there. Not sure why I had 10 or so images that came out then nothing for 10 more images, then I change the lens and everything works again.
A stupid reason from @jankap, but I could also not know another one, for a lens being a problem, though at least you would have black images which are numbered.
Dirty contacts may be? Either between camera and lens or camera and battery?
Edited by Olaf_ZG
The card is a SanDisk 8GB HCI, It has worked with the camera for years, well the 6 I have had it. I always format the card in camera. The bizzare thing is I didn't turn camera off and on, it was working fine up until xxx740 then stopped and started up again at xxx750 with another lens. I remeber the shutter firing, I think. But it still it shouldn't drop numbers.
