setuporg Posted August 23 Share #1 Posted August 23 Advertisement (gone after registration) My M-P sometimes sounds like it jams. A shot makes a curtailed shutter sound and then you cannot make more shots until you turn off/on again. Pressing the button does nothing when jammed. Happens about 1/1000 shots. I let it be, but recently during a trip the jamming would not go away for a while. Even removing and reinserting the battery was not doing it. I was using a multifunctional grip. Finally I took off the grip and did the battery reinsert and turned the camera on without reattaching the grip, that fixed it and then I put the grip back on. Any pattern of misfiring and what does it mean? Link to post Share on other sites More sharing options...
Advertisement Posted August 23 Posted August 23 Hi setuporg, Take a look here M-P 240 misfires occasionally. I'm sure you'll find what you were looking for!
jdlaing Posted August 24 Share #2 Posted August 24 (edited) 5 hours ago, setuporg said: My M-P sometimes sounds like it jams. A shot makes a curtailed shutter sound and then you cannot make more shots until you turn off/on again. Pressing the button does nothing when jammed. Happens about 1/1000 shots. I let it be, but recently during a trip the jamming would not go away for a while. Even removing and reinserting the battery was not doing it. I was using a multifunctional grip. Finally I took off the grip and did the battery reinsert and turned the camera on without reattaching the grip, that fixed it and then I put the grip back on. Any pattern of misfiring and what does it mean? You’ve answered your own question. Check the contacts on the body and grip are clean. Edited August 24 by jdlaing 1 Link to post Share on other sites More sharing options...
setuporg Posted August 24 Author Share #3 Posted August 24 That happened without the grip as well. Link to post Share on other sites More sharing options...
jdlaing Posted August 24 Share #4 Posted August 24 6 hours ago, setuporg said: That happened without the grip as well. Could be the battery contacts too. 1 Link to post Share on other sites More sharing options...
jto555 Posted September 7 Share #5 Posted September 7 I would suspect a shutter issue. I have been down this road many times and a trip back to Leica for the camera is called for. 1 Link to post Share on other sites More sharing options...
