Mike G. Posted 16 hours ago Share #1 Posted 16 hours ago Advertisement (gone after registration) Both my main cameras, R8 and R9 I use with the Digital Modul-R, after being idle for a few years are now apparently dead. Fully charged batts and still will not function. Electronic readouts on the R9 respond but shutter releases don't work. The R8 doesn't show anything in either the rear window or viewfinder and it too does not shutter release.. Both cannot be advanced manually either. I hope someone can help me figure out what the issues could be. This one has me stumped. Link to post Share on other sites More sharing options...
Advertisement Posted 16 hours ago Posted 16 hours ago Hi Mike G., Take a look here R8 and R9 dead after long period being ide. I'm sure you'll find what you were looking for!
Photar Posted 16 hours ago Share #2 Posted 16 hours ago Did you try to remove the digital backs to see whether the cameras work on their own? Link to post Share on other sites More sharing options...
erl Posted 15 hours ago Share #3 Posted 15 hours ago Try fitting the film back and FRESH batteries. The problem could be the Digital Modul-R. I hope not! Or maybe just the batteries. Good luck. Fantastic cameras. Link to post Share on other sites More sharing options...
spydrxx Posted 13 hours ago Share #4 Posted 13 hours ago If the above suggestions don't solve your issues, you might contact Sherrie Krauter. Although quirky she is perhaps the most experienced and knowlegible US repairperson for R cameras. Link to post Share on other sites More sharing options...
Sandokan Posted 11 hours ago Share #5 Posted 11 hours ago 4 hours ago, Photar said: Did you try to remove the digital backs to see whether the cameras work on their own? 3 hours ago, erl said: Try fitting the film back and FRESH batteries. The problem could be the Digital Modul-R. I hope not! Or maybe just the batteries. Good luck. Fantastic cameras. +1 - the DMR battery gets unable to sustain a charge. You can buy replacement cells but have to swap them out yourself 1 Link to post Share on other sites More sharing options...
250swb Posted 9 hours ago Share #6 Posted 9 hours ago The common denominator seems to be the Module, so very good advice to fit the film backs to narrow it down. Link to post Share on other sites More sharing options...
jaapv Posted 5 hours ago Share #7 Posted 5 hours ago Advertisement (gone after registration) 6 hours ago, Sandokan said: +1 - the DMR battery gets unable to sustain a charge. You can buy replacement cells but have to swap them out yourself Many services that replace laptop cells will do so for DMR batteries as well. However, this can be caused by dirty/oxidized contacts. Clean spray will. help. 1 Link to post Share on other sites More sharing options...
jaapv Posted 5 hours ago Share #8 Posted 5 hours ago 7 hours ago, spydrxx said: If the above suggestions don't solve your issues, you might contact Sherrie Krauter. Although quirky she is perhaps the most experienced and knowlegible US repairperson for R cameras. AFAIK she won't touch anything to do with digital. Link to post Share on other sites More sharing options...
