LUF Admin Posted May 12 Share #1 Posted May 12 Advertisement (gone after registration) The latest firmware update v.3.1.1 for the Leica Q3 and Q3 43 introduces new features, improvements, and enhanced performance. Here are the download links and the changes: Downloads: Leica Q3 Leica Q3 43 Alternatively, the firmware can be installed via the Leica FOTOS app. New: The requirements of Lot6/Lot26, Regulation (EU) 2023/826 on ecodesign are supportedThis firmware update ensures that the camera now complies with the latest EU ecodesign regulations, making the Leica Q3 and Q3 43 more environmentally friendly and energy-efficient. New menu section AF Settings, where AF Sensitivity and AF Speed can be adjusted individuallyA new menu section allows users to adjust AF sensitivity and speed independently, providing greater control over autofocus performance. The menu item AF Tracking Start Position was moved to the menu area AF SettingsThe AF Tracking Start Position menu item has now been moved to the AF Settings section for more streamlined navigation and easier access. Improvement: New setting option for continuous shooting with autofocus: 5 fps, 12-bit, AFThe continuous shooting mode now supports 5 fps at 12-bit depth with autofocus, improving performance for fast-action photography. The function Toggle Focus Point is now accessible via the FN buttonThe Toggle Focus Point function can now be activated quickly via the FN button, allowing for faster focus adjustments during shooting. Electronic shutter speed 1/16000 s will now be available for P/A modeThe electronic shutter speed of 1/16000 s is now available in Program (P) and Aperture Priority (A) modes, offering finer control over exposure, especially in bright lighting conditions. Link to post Share on other sites More sharing options...
Advertisement Posted May 12 Posted May 12 Hi LUF Admin, Take a look here Firmware Update 3.1.1 Leica Q3 / Q3 43. I'm sure you'll find what you were looking for!
bgreig Posted May 13 Share #2 Posted May 13 What is the “toggle focus point” and which button now controls it? How does toggling work? New to this and just learning. Thanks Bgeeig Link to post Share on other sites More sharing options...
Tarekith Posted May 13 Share #3 Posted May 13 It toggles between resetting the focus point to the middle of the screen and where the focus point was previously. You can assign it to any button you want. 1 Link to post Share on other sites More sharing options...
Qwertynm Posted May 15 Share #4 Posted May 15 On 5/12/2025 at 11:06 AM, LUF Admin said: This firmware update ensures that the camera now complies with the latest EU ecodesign regulations, making the Leica Q3 and Q3 43 more environmentally friendly and energy-efficient. what does that mean in detail? My De'Longhi Nespresso machine auto shuts off after 120seconds instead of the advertised 9min and it's annoying as ****. 3 Link to post Share on other sites More sharing options...
Cal Posted June 13 Share #5 Posted June 13 Hello there, I'm visiting this forum for a long time, but this its my very first comment here. I own a Q3/28 which has not any firmware installed in it. My dumb question is as follows: do i need to install successively all of the firmware versions launched up to this date or does it suffice to install the latest update 3.1.1.? Thanks in advance for any inputs in this regard. Cal Link to post Share on other sites More sharing options...
Smogg Posted June 13 Share #6 Posted June 13 6 minutes ago, Cal said: Hello there, I'm visiting this forum for a long time, but this its my very first comment here. I own a Q3/28 which has not any firmware installed in it. My dumb question is as follows: do i need to install successively all of the firmware versions launched up to this date or does it suffice to install the latest update 3.1.1.? Thanks in advance for any inputs in this regard. Cal You just need to install the latest version. Link to post Share on other sites More sharing options...
Trankster Posted June 13 Share #7 Posted June 13 Advertisement (gone after registration) Be sure to export (back up) your user profiles before installing the update. To restore your profiles, you can import after the update. Link to post Share on other sites More sharing options...
Cal Posted June 14 Share #8 Posted June 14 21 hours ago, Smogg said: You just need to install the latest version. Thank you, Smogg Link to post Share on other sites More sharing options...
Cal Posted June 14 Share #9 Posted June 14 21 hours ago, Trankster said: Be sure to export (back up) your user profiles before installing the update. To restore your profiles, you can import after the update. Thanks for the input, Trankster Link to post Share on other sites More sharing options...
Robert Ardinger Posted June 14 Share #10 Posted June 14 (edited) One last thing is that if you want the image file number sequence to stay sequential to the last image taken (and if you are updating via an SD card and reformatted the card before adding the update file) take a picture first (after the reformat) so that a file with the last sequential number (i.e. Q1000XXX.DNG) will be in the "100LEICA" folder (which is inside the DCIM folder)(can also just drag the last image file from your computer into this location when adding the firmware file). Otherwise the numbering starts again from Q1000000 and, depending or not if you rename the image files on your computer, you could have two different files with the same "name (number)". Edited June 14 by Robert Ardinger 2 Link to post Share on other sites More sharing options...
Cal Posted June 22 Share #11 Posted June 22 Thanks for the info, Robert Link to post Share on other sites More sharing options...
Smogg Posted July 28 Share #12 Posted July 28 On 5/12/2025 at 12:06 PM, LUF Admin said: Improvement: The function Toggle Focus Point is now accessible via the FN button The Toggle Focus Point function can now be activated quickly via the FN button, allowing for faster focus adjustments during shooting. The Toggle Focus Point function is extremely convenient in face detection mode, when face detection is unstable or you want to temporarily quickly turn it off and focus on the central point. Thanks to the developers for this innovation. However, I ask the developers to slightly improve this function. This function, as it should, works once when you half-press the shutter button. But for some reason it does not work if you focus not with the shutter button, but with the AF-L function key (if you assigned such a function to the button) 1 Link to post Share on other sites More sharing options...
