Posted (edited)
I am trying to find out more about what happens in my M11 if lens detection is on (other than where EXIF data are concerned). Are any lens corrections written into the DNG? Only into "metadata"? Is Adobe PS lens correction just activating what is on the DNG that comes straight out of the camera - or is it "in addition"? In (Adobe PS) post-processing, could I get rid of the in-camera lens corrections (e.g., by not activating the correction in Adobe PS)?
Curious to learn from anyone who can shed a light on this, also whether you are using lens detection or if you have deactivated.
Apologies if this topic has been covered elsewhere. Thanks
Edited by ApoVision
typo
A DNG is a container file that consists of out of camera data,  data pertaining to the settings of the firmware, EXIF data,, a small jpg thumbnail, etc, all under the DNG format. There may be an XMP sidecar file ( Extensible Metadata Platform ). Your postprocessing process will convert those data into usable files.
However, raw data are not a sensor dump. The sensor output will be digitalized, demosaiced , interpolated and processed by the camera firmware before being incorporated in the DNG format output.
https://www.theschoolofphotography.com/tutorials/dng-vs-raw
https://www.adobe.com/creativecloud/file-types/image/raw/dng-file.html
So yes, you can switch off lens corrections in PS, LR etc.  There are even a few postprocessing programs that don’t recognize them.
Not true... or not always true for DNG files out of the camera.  It is true that Adobe's DNG converter will demosaic proprietary raw formats when converting to DNG format.  That will also be true of DNGs created by Lr, etc, when doing denoise, panorama, hdrs, etc.
That later kind of file is what the DNG spec refers to as Enhanced Image Data.  It came with version 1.5.00 of the DNG spec.  Adobe says:
DNG 1.5.0.0 adds the concept of enhanced image data, which is a more processed (and always at least demosaiced) version of the raw image data.
Posted (edited)
But the OP is asking about Leica's DNG files specifically.
Edited by pedaes
We are talking about Leica with native out of camera DNG You are talking about other, proprietary raw formats converted to DNG  in Adobe’s DNG converter.
Lightroom says this about the DNG files created by my M11:
I believe the line  "Mosaic Data Yes" indicates the file had not been demosaiced.
DNG output from Leica cameras is not demosaiced. Demosaiced data is not really raw data.
Also, DNG converters do not demosaic raw data, except when converting to linear-DNGs.
Posted (edited)
DNG is just an "open container" specification from Adobe. It can contain everything from raw luminance data from the sensor (in the case of Leica and a few other cameras) to linear (slightly demosaiced data) to fully cooked (JPEGs/TIFs).
Leica's DNG files are raw luminance data fully available for you to manipulate in your raw converter of choice.
Edited by Ray Harrison
