I bought a brand new M11-P in Nov 2024. My pictures have gray spots at the same area of my pictures, see sample. I see the spots on pictures shot on both my 35mm summicron as well as my 50 summilux. Since I have purchased the camera, I must have swapped the lenses less than 10 times and all of them in house. I don't see anything on the sensor. Any thoughts on how to get this fixed.
These spots look like sensor dust. I had some on my M11 and I would suggest trying using a blower first whilst holding the camera with the sensor facing downwards.
In the UK, Leica offer two free sensor-cleans p.a. whilst under warranty. I am not sure what the position is in the US.
Out of warranty cleans by Leica cost £90 In the UK.
Good luck with it.
Without a powerful loupe you will not see anything.
I would strongly advice you to get a wet clean with correct fluid, as it is very common for new cameras to throw out tiny splats of oil. This is easy to smear (you will find a recent Thread covering this very issue ) which then looks worse!
You will be unlucky if you have more oil spots after first clean.
Thank you all for your suggestions. I'm surprised, given the cost of the camera, and the reputation of Leica quality, something like this would slip their quality control! I will start with bulb blower, then Leica cleaning service.
Dust spots/stains are unavoidable on any interchangeable lens digital camera. It’s annoying when you get them early on but as suggested I would try the blower first and then if they still bother you, a wet clean. Easy enough to do yourself. This forum and YouTube have a fair amount of resource if needed. The alternative is to take it to a pro for a clean.
It only takes a single lens swap to get dust on the sensor.  Removing the protective cover and installing a lens when first getting the camera can do it.  Sometime I can go for a few years with a clean sensor. Other times I get dust immediately.  I don't know the reason for the differences.  Environment? Humidity?  Build up of static electricity because reasons?  Something else.
Most of the time a half a dozen blasts with a rocket blower cleans the sensor.  Sometimes I have to break out the sensor brush.  I haven't had to do a wet cleaning on my M11, yet.  I've got the kit, though.  Had to use in on my M 262 after many years of use.
Posted (edited)
This is completely normal for changeable lens digital cameras, paying £££ does not remove dust from your personal world;-)
For me blower works 70% of the time and a charged sensor brush the rest. I usually end up cleaning them about 4 monthly.
i do wonder if an ultrasonic cleaning function would help a bit.
Edited by Derbyshire Man
You guys are awesome! The bulb blower job did it, see attached. Thank you.
Even if you don't see macro-dust spots over the years, it is wise to wet-clean a sensor once or twice a year. Micro-dust AKA haze from the ambient air will settle and reduce contrast and clarity over time, like on the windows of your home or even inside lenses. I live near the beach (salt and sand micro dust), The A15 is within 10 km (Rotterdam Harbour into Germany- an untold number of diesel trucks- and inland from where I live there is plenty of industry - I see results from a quick wet clean twice a year.
