I am keen to experiment with my newly acquired Leica R6.2 but need some advice.
My preference is for Black/white so I habitually use FP4 which my previous camera handled sensibly. However the 6.2 ISO setting options are 100/200 and so on, and it looks like there is no inbetween setting..
From experience, can anybody suggest the most appropriate settings to give best results in this circumstance - 200 or 100 with adjusted shutter settings?
I'd be grateful for advice.
I've just had another look at the ISO setting on my R 6.2 to be on the safe side and there's no problem setting it to 125 ISO (ASA/21 DIN). There is a small line for 125 and 160, not as big as the number, but still recognizable. Just give it a try. Apart from that, film - as spydrxx has already said and especially the FP4+ - is more forgiving than you might think.
Have fun with the R 6.2, which is a really great SLR camera 😀
I don't have a 6,2, but I assume it is the same as my R6, which has markings for 100 & 200, but there are 2 "click stops" between them. For FP4 I'd use the first "click" past 100. (Set it at 100, press the ISO lock button and just as you start to turn away from 100 let the button up as you turn and it will click into the next setting.)
I used to have an R6.2, as I recall the ISO setting operation was the same as on the R5.  I used the first available between ISO 100 and ISO 200 as shown here:
You guys are really a gold mine - thank you so much. Just trying to get to know the camera itself I had not noticed that tiny slot above the main number.
We never stop learning! I have just traded my R3 for this camera and amazed that it came with original display box and packaging, unused strap and original instruction leaflet (I had downloaded a copy already) but extremely inpressed with the quality visually so shall attach my Summicron 50mm f2 lens and get shooting.
  • 2 weeks later...
It may need it for the self timer, I do not recall.  I can tell you over 8 years I have only used my M3 self timer once!  I haven't missed that on the R6.2.  Good catch.
David.
David.
You re right, I do not recall any occasion on which I actually used the self-timer on my R6.2, I did use it on my R5 a few times though.
