In an era where camera lenses seem to be growing ever larger—bloated mirrorless behemoths with oversized front elements—it’s easy to forget how elegant and compact lenses once were. This is why I find myself returning, time and time again, to Leica’s small E39-thread lenses for the M system, particularly the Summicrons from the 1960s and 1970s (and Summarits from more recent years).
There is something almost poetic about their size. These lenses don’t shout for attention; they whisper. Mounted on an M body, they keep the camera balanced and discreet, ready to slip into a pocket rather than demand a dedicated bag. There’s a refinement to their compactness, an almost feminine elegance that today’s oversized glass seems to lack.
The 35mm and 50mm Summicrons from this era are perfect examples—sharp, but never clinical, with just the right amount of character. And the Summarits? Even smaller, almost jewel-like, yet still producing images with that unmistakable Leica signature.
In a world obsessed with technical perfection, huge apertures, and ever-larger lens elements, these classic E39 lenses remind us of something different: photography as a craft, not just a competition for the biggest and fastest. Small can be beautiful. In fact, it often is.
Would love to hear from others who still appreciate these compact masterpieces! What’s your favorite small Leica lens?
  • Like 14
1 hour ago, Deeetona said:
-- that unmistakable Leica signature.
In getting better larger and indeed macho size large aperture lenses there are trade-offs we don't understand. Like the type of aberrations. They are not 'perfect'.
  • My Summilux 35mm FLE is sharp, sure, and sharper, sure, than the 39mm filter size lenses (35mm summicron version 1, 4 that I have). But - I thought coma would be less (true - but if it is there, it is worse: a complete flare instead of a blot).
  • Same goes for a type of lateral aberrations where out-of e.g. focus glasses of a person are depicted twice sometimes. You might get ghost branches in the corners...
So - that technical perfection that you even can't see beyond F4 should be chosen for composition, not quality. Keep your lenses small. 80% of the time.
My next hike has f/2.8, f/2.4 and f/2 in the bag.
Among the 90mm lenses the Elmar M 90mm Version II (3lenses) is my favourite lens.
Edited by Scrapbook
2 hours ago, Deeetona said:
In an era where camera lenses seem to be growing ever larger it’s easy to forget how elegant and compact lenses once were. This is why I find myself returning, time and time again, to Leica’s small E39-thread lenses for the M system...
I'm a great advocate of small lenses. Here are my typical 'Go-To' focal-length picks with notes showing extension from body-flange to front-edge of the filter rim;
21mm f4.0 Super-Angulon : 27mm.
28mm f2.8 Elmarit ASPH (v1) : 29mm.
35mm f2.0 LLL '8 Element' (v1 Summicron Clone) : 28mm.
35mm f1.4 Summilux (v2) : 28mm.
40mm f2.8 Rollei Sonnar : 24mm (and still only 28mm with hood fitted!).
40mm f1.4 Voigtlander Nokton : 29mm.
50mm f2.0 Summicron (v4) : 41mm.
All bar the Nokton and Summmilux have a 39mm thread which, as someone who uses filters all the time, is another reason these are my favourites. I have UVa, Circ. Pola and Red for the former and quite a few Series VII for the latter. My plan is to acquire a second 12504 hood as this can be used with the 28mm (which surprised me!), the two 35mm lenses and the 50mm therefore swapping different filters from one lens / body pairing to the other when out snapping would be a matter of just a few seconds.
It is notable that only the 50 Summicron is greater than 29mm in length. A Tiny Bunch of Lenses Indeed!
Philip.
A real man always says: size doesn’t matter.
Edited by Elliot Harper
vor 23 Stunden schrieb Deeetona:
Well, this sounds rather poetical - though I fear it's a myth to believe that Leica lenses generally were the smallest.
If you look at a 1:2.8/35mm Summaron it seems small. Though if you compare it to a 1:2.8/35mm Biogon for the Contax it becomes a lot bigger.
Same with the comparison of a 1:2.8/35mm Rodenstock Heligon, even though 1mm for an LTM-to-M adapter is added:
I could go on with comparisons of a Zeiss Ikon 1:1.5/50mm Sonnar to a 1:1.5/5cm Summarit or 1.4 Summilux, a 1:2/85mm Sonnar to a 1:2/90mm Summicron, 1:4/135mm Sonnar to 1:4/135mm Elmar - and the Leica lenses would seem huge. Leitz/Leica certainly will not win the contest "Who has the smallest?".
Though smallness isn't always a reasonable aim. With all lenses from other producers I mentioned the front element will turn around when you focus them, not so with most contemporary Leica lenses (the late 90mm Elmar with 3-elements being a rare exception); you need space for the mechanism. And setting the f-stop for a 35mm Contax lens is just awkward: you have to use the tiny filter ring in the front - almost as impractical as the old 35 or 50mm Elmars with the fingernail setting for f-stops
You mentioned the late Leica Summarit series as an example for lenses with 39mm filter threads. That's true for 35 and 50mm of the earlier versions with f/2.5 - the 75 and 90mm already had 46mm. The later version with f/2.4 all had 46mm filter threads, which I think was a good idea if you look at many other current Leica-M lenses from 21 to 75mm with 46mm filters. And last but not least: the hoods. The earlier variant of the current 50mm Summicron needed a separate hood, which made the whole lens a lot larger. Now the Summicron has an inbuilt hood: smaller but much less effective.
Very happy with my summaron 28mm
Edited by jps1
10 hours ago, UliWer said:
...Leitz/Leica certainly will not win the contest "Who has the smallest?"...
I don't believe that such was their primary goal.
Anyhow; it gets to the point where miniaturism defeats practicality. Miyazaki et-al take a bow,
Philip.
Edited by pippy
Have to agree with everything positive mentioned so far and this applies to the fast F1.2/ F1.4 lenses too.  Apart from the quality images and prints etc etc - the small factor simply makes for a fun and enjoyable experience which I guess eventually benefits image output.
My favorite small Leica lenses (and the only two I have at the moment) are the 35mm Summilux v2 and the 50mm Summilux v3 (admittedly E46, but still small and neat). Lately I've started to miss my 35mm Summicron v4 again (due to shorter MFD) and I'm very curious about the 50mm Summicron v5 (much thanks to many great pictures here on the forum).
Am 4.2.2025 um 02:22 schrieb lct:
I thought the OP was referring to LTM lenses, not M lenses with 39mm filters sorry.
LTM lenses with 39mm filters were only a few years available, parallel to the same lenses for the then new M-bayonet.
Small LTM lenses before only had diameters for the attachable A-36 filters, some like the famous Elmar 3.5-50mm the very small screw-in filter E19.
Beginning Leica photography in 1992 with an used M3, I paid attention when buying also used lenses to the uniform filter size E39.
It started with: Summicron-M 2.0-35mm and Elmar-M 4.0-90mm.
Later were added: Super-Angulon-M 4.0-21mm, Summicron-M 2.0-50mm, and Tele-Elmar-M 4.0-135mm.
50 and 90mm lenses were the space-saving collapsible versions.
On 2/3/2025 at 5:35 PM, pippy said:
All bar  My plan is to acquire a second 12504 hood as this can be used with the 28mm (which surprised me!),
Hello Pippy, FYI, the LLL version of the 12504 lens hood may be worth a look at...........I've a couple of them and they work very well. Cheaper than a Leica branded one bought off of Ebay and "NEW" with a UV filter at about €70.00...........https://lightlenslab.com/products/light-lens-lab-12504-lens-shade
