johnson184 Posted February 2 Share #1 Posted February 2 Advertisement (gone after registration) I'll be getting a 75mm Noctilux, but I'd like to also shoot wide open during daytime. Any suggestions as to which to go with? Has anyone tried one of the variable ND filters from PolarPro/Peter McKinnon or B&W? Is there any drawbacks besides price? Link to post Share on other sites More sharing options...
Advertisement Posted February 2 Posted February 2 Hi johnson184, Take a look here ND Filter recommendations for 75mm Noctilux?. I'm sure you'll find what you were looking for!
3D-Kraft.com Posted February 2 Share #2 Posted February 2 I am using a 3-stops B&W filter. For photos, that's sufficient to bring down the light, so that you can use the M9 at it's 1/4000s limit with the lens fully open. I don't like variable ND filters for many reasons. I would only use them for videography. Link to post Share on other sites More sharing options...
johnson184 Posted February 3 Author Share #3 Posted February 3 Looking into it more, it appears I should definitely go with a fixed ND filter instead of a variable for maximum image quality. Looks like the best options available are the B&W 3 Stop, the Breakthrough X4 3 Stop, and Leica's own 4 Stop. Would love to hear more feedback from everyone. Kinda curious why Leica themselves only make a 4 Stop and not a 3 Stop. Link to post Share on other sites More sharing options...
PhotoCruiser Posted February 3 Share #4 Posted February 3 vor 10 Stunden schrieb 3D-Kraft.com: I don't like variable ND filters for many reasons. As i am looking for a ND filter i would like to know more detailed why you don't recommend them. Chris Link to post Share on other sites More sharing options...
3D-Kraft.com Posted February 3 Share #5 Posted February 3 vor 1 Stunde schrieb PhotoCruiser: As i am looking for a ND filter i would like to know more detailed why you don't recommend them. I only dislike the variable ND filters, not ND in general. You may see some color shift and uneven light distribution. See also here: https://blog.dominey.photography/2021/08/09/should-you-buy-solid-or-variable-neutral-density-filters/ 1 Link to post Share on other sites More sharing options...
LeicaR10 Posted February 3 Share #6 Posted February 3 (edited) PhotoCruiser, I agree with 3D-Kraft's post #5. The variable NDs do not work well with wide angle lenses. I most highly recommend you consider the Breakthrough Photography X4, 3 Stop or 6 Stop ND (for really bright sunlight, i.e. deserts). These are color neutral filters and simply work. I have used them for many years with most excellent results. r/ Mark Try: https://breakthrough.photography/products/x4-neutral-density?variant=30850759697 Edited February 3 by LeicaR10 3 Link to post Share on other sites More sharing options...
PhotoCruiser Posted February 3 Share #7 Posted February 3 Advertisement (gone after registration) Sorry, i forgot to write variable ND filters, my bad. I know ND filters and use them, but stumbled over the variabe ones and thought that it's a good idea, but obviously not. So this is the problem, now i understand. vor 37 Minuten schrieb 3D-Kraft.com: You may see some color shift and uneven light distribution. Chris Link to post Share on other sites More sharing options...
farnz Posted February 4 Share #8 Posted February 4 My (variable) 'ND filter' for my 75 Noctilux is the electronic shutter in my SL2-S that offers up to 1/32,000th shutter speed. No, not an ND filter as such but a different and convenient work-around. Pete. Link to post Share on other sites More sharing options...
Drmat Posted February 4 Share #9 Posted February 4 I use b+w 3 stop ND filter on M10M and M11M. Mostly for portrait work at F1.25. Filters are good quality and I have not found a need for anything stronger, even in hard sunlight. Link to post Share on other sites More sharing options...
T25UFO Posted February 4 Share #10 Posted February 4 Don't have the 75mm but use a X4 3 stop from Breakthrough Photography on my 50mm Noctilux. Breakthrough has the most neutral balance of any ND filter I have used. Thoroughly recommended. 1 Link to post Share on other sites More sharing options...
