Dr. G Posted January 4 Share #1  Posted January 4 Advertisement (gone after registration) Is there any way to set the exposure target at -1/3 or -2/3 EV in manual mode when using Auto ISO? In other words, can I have full control of shutter and aperture with a floating ISO that doesn't always adjust itself to expose for the center of the light meter? I like to shoot slightly underexposed for the way colors render and have always just adjusted the ISO manually if there were quickly changing lighting conditions, but at some events having the camera make the adjustments could be easier. Link to post Share on other sites More sharing options...
Advertisement Posted January 4 Posted January 4 Hi Dr. G, Take a look here Question About Auto ISO in Manual Mode on SL3. I'm sure you'll find what you were looking for!
SrMi Posted January 4 Share #2  Posted January 4 25 minutes ago, Dr. G said: Is there any way to set the exposure target at -1/3 or -2/3 EV in manual mode when using Auto ISO? In other words, can I have full control of shutter and aperture with a floating ISO that doesn't always adjust itself to expose for the center of the light meter? I like to shoot slightly underexposed for the way colors render and have always just adjusted the ISO manually if there were quickly changing lighting conditions, but at some events having the camera make the adjustments could be easier. I do not understand the question. You already have complete control of shutter speed and aperture in the "manual" mode (M mode). You can apply EC if you use Auto ISO, which will only affect the ISO. Link to post Share on other sites More sharing options...
Dr. G Posted January 4 Author Share #3  Posted January 4 That was my question. So basically I'm setting the Exposure Compensation to -1/3 or -2/3 EV on the Quick Menu Page and I should see the ISO drop with the same shutter speed and Aperture?  Link to post Share on other sites More sharing options...
SrMi Posted January 4 Share #4  Posted January 4 23 minutes ago, Dr. G said: That was my question. So basically I'm setting the Exposure Compensation to -1/3 or -2/3 EV on the Quick Menu Page and I should see the ISO drop with the same shutter speed and Aperture?  Yes. When the metered ISO is higher (in A and M mode), I often use negative EC with Auto ISO to protect highlights without reducing exposure. Link to post Share on other sites More sharing options...
