EddieCheddar Posted December 29, 2024 Share #1 Posted December 29, 2024 Advertisement (gone after registration) Hello all. Leica M11. Power saving set to 2 minutes. Display saving set to 1 minute. After one minute, the display turns off. After two minutes “power saving mode” goes into effect, but then there’s no way to wake up the camera. Shutter press does nothing. The camera just turns completely off after two minutes and I need to turn the power switch to off, then back on again, to get it to work. I’ve tried with different time settings, different lenses, different batteries and nothing works. Again, once the camera goes into power saving mode I can not wake up the camera (without manually turning the camera off then back on). What am I doing wrong? Your suggestions are greatly appreciated. thanks in advance. Link to post Share on other sites More sharing options...
Advertisement Posted December 29, 2024 Posted December 29, 2024 Hi EddieCheddar, Take a look here Power Saving — not waking up with shutter. I'm sure you'll find what you were looking for!
Smogg Posted December 29, 2024 Share #2 Posted December 29, 2024 36 minutes ago, EddieCheddar said: Hello all. Leica M11. Power saving set to 2 minutes. Display saving set to 1 minute. After one minute, the display turns off. After two minutes “power saving mode” goes into effect, but then there’s no way to wake up the camera. Shutter press does nothing. The camera just turns completely off after two minutes and I need to turn the power switch to off, then back on again, to get it to work. I’ve tried with different time settings, different lenses, different batteries and nothing works. Again, once the camera goes into power saving mode I can not wake up the camera (without manually turning the camera off then back on). What am I doing wrong? Your suggestions are greatly appreciated. thanks in advance. I set Power saving to an hour, the battery practically does not discharge, and the camera allows you to shoot instantly. Link to post Share on other sites More sharing options...
lct Posted December 29, 2024 Share #3 Posted December 29, 2024 2 hours ago, EddieCheddar said: I’ve tried with different time settings, different lenses, different batteries and nothing works Did you try to remove the card? Link to post Share on other sites More sharing options...
J S H Posted December 30, 2024 Share #4 Posted December 30, 2024 What firmware is installed on the camera? I believe this was one of the bug fixes in the last few versions. If you are up to date, I would recommend that you perform a full camera reset and then rebuild any saved profiles. Link to post Share on other sites More sharing options...
