180 Summicron-R Wimberley plate
anabasis
I have just ordered a 180 Summicron R and want to use it with my Wimberley Head II and R8. I wonder if there is anyone on the forum who has used this lens with this tripod head, and if so, what plate is best?
I contacted Wimberley and they don't have a definate recommendation for this lens but are suggesting that I try a P-30 plate.
I can't wait to try this lens out. :D
JCA
x
Hi Jeremy,
Congratulations on the lens. It's super. I use mine on a ballhead with a Markins PL70 plate. The plate is 2.8 inches long and works nicely.on a ballhead. I use R9+DMR. With R9+DMR, the camera is too heavy, so I cannot get the gear to balance correctly, because camera hits the quick release clamp vertical level adjustment screw. Also, with the lens this forward, it's a little awkward to use the focusing ring. With this setup (R9+DMR), you would have about 4 3/8 inches from the front of the tripod foot to the front of the camera (mainly the DMR part that would be equivalent to the motor drive position). If you don't use a motor drive, the Wimberley P30 plate (4.43 inches long) will probably work.
Hope this helps.
Peter
Great combination. I have not used that particular lens, but have used a DMR/R8 combination with a 105~280 Vario-Elmar-R lens and a 3 1/4 inch Really Right Stuff plate on the Winberly Head and it works very well.
John
Sorry if I'm being naive, but are we talking about mounting the camera/lens combination by the lens tripod bush rather than the camera bush? Surely the former is preferable; would this affect the optimum choice of plate?
Thanks for all of the responses. I use the R8 with the Motor-R most of the time. If there is a major issue with the tripod plate on the lens, I will forgo the MD and just use the manual winder. As for the DMR, I just can't justify to myself spending an extra $1000 on it instead of a D3. Besides, I love slides from the Leica glass, and from what I've read here and elsewhere, the 180 is one of Leica's best ever.
Fortunately I have several plates already for my long Nikon glass, so I will just have to experiement to see which plate works best to balance this combination.
I should get the lens tomorrow and will have to see what we can do and report back as to which plate works the best.
JCA
JCA
Jeremy
Even if there is a major issue using the mounting bush on the lens, I would think very hard before using the camera bush. Even with the 280/4 (which is not as heavy as the 180/2) Leica say that a neck strap should be mounted on the lens, not on the camera. Then the lens mount bears the weight of the camera, not the weight of the lens. I would have thought that the same caution might also apply to mounting the combination on a tripod. Just a thought - though maybe I'm a bit overcautious !
I managed to mount the 180 Summicron on my R8+MD and put in on the tripod head. I am going for the P-20 plate instead of the P-30. The extra length of the P-30 isn't necessary. There isn't much clearance between the front of the MD and the back of the plate, but the whole rig balances perfectly. I am not sure the weight difference between the Motor-R and the DMR, but that would certainly affect the center of gravity and therefore the plate you might need to use as well as its position.
While the tripod foot is very solid, focusing and adjusting the aperture ring while on the mount is a bit awkward and I will have to get used to their respective positions.
To be clear, I would NEVER mount any lens of this size on a body and then use the camera tripod mount. My philosophy is that if the lens has a tripod foot on it, it is going to be used instead of the camera's bushing.
Thanks for the input from everyone.
JCA
PS picture of the rig on the tripod is on flickr.
