From a 35mm film camera perspective: considering the Voigtlander 15mm 4.5 V1 screw mount and VM/V2 M mount, other than rangefinder coupling of the V2 (which arguably is not needed at 15mm) any reason for choosing the V2 over the V1?
From a 35mm film camera perspective: considering the Voigtlander 15mm 4.5 V1 screw mount and VM/V2 M mount, other than rangefinder coupling of the V2 (which arguably is not needed at 15mm) any reason for choosing the V2 over the V1.
Few notes:
To be used on 35mm film (colour and B&W) or Digital M9 (B&W)
The V1 focuses closer at 30cm while the V2 focuses closest at 50cm. This makes a difference in relative subject size in the frame.
V1 cant take filters but V2 can
V1 shorter and less wide
V1 VF easier to look through but plastic fantastic. V2 VF lovely, compact and all metal. Well made. But more difficult to look through.
_ _ _ _ _ _ _ _ __ _ _ _ _ _ _ _ __ _ _ _ _ _ _ _ __ _ _ _ _ _ _ _ __ _ _ _ _ _ _ _ __ _ _ _ _ _ _ _ __ _ _ _ _ _ _ _ __ _ _ _ _ _ _ _ __ _ _ _ _ _ _ _ __ _ _ _ _ _ _ _ __ _ _ _ _ _ _ _ __ _ _ _ _ _ _ _ __ _ _ _ _ _ _ _ __ _ _ _ _ _ _ _ _
Final point and just for fun: If you weren't using on film but rather only on digital and colour, would it make a difference for the above and your final answer?
I bought the V1 on my M6. Great. Just guess the close focus (like the length of a hand or elbow).
On the M8 it became an incredible 21mm - no IR/UV needed! And I could check the focus if needed by review. On any Monochrom it is great too.
On the M240/M10 the sides were nastly coloured. Too bad. --> the V2 was supposed to improve that. But for film that new version is not needed.
So my feedback is: go for the V1. Small. Versatile.
Have a look at the Laowa 15mm F/5. This lens is at least equal, if not superior to the V1 and V2. I own it and tested it against my V3 15 F/4.5 and it performed about the same. The Laowa is a little better close up and the Voigtlander was just a bit better at infinity. Those differences will not show up on film and the Laowa is incredibly small with 39mm filter threads. It also focuses to just under 5 inches!
https://www.bhphotovideo.com/c/product/1861635-REG/venus_optics_ve1550mblk_laowa_15mm_f_5_cookie.html/?ap=y&ap=y&smp=y&smp=y&store=420&smpm=ba_f2_lar&lsft=BI%3A514&gad_source=1&gbraid=0AAAAAD7yMh0Sk__YEVfT9Ut6zyiRCet2K&gclid=CjwKCAiAjp-7BhBZEiwAmh9rBUZcNwVzJY7-GGLZIQcIhKSQzHxs9-wLO3s0Zw3jrU2hid40rZUzlhoC5UkQAvD_BwE
Bastian's review is here: https://phillipreeve.net/blog/review-laowa-15mm-5-0-cookie-tiny-and-useful/
Heliar 15/4.5 v1 and v2 share the same optics according to Cameraquest so the only interest of v1 would be a closer MFD and a lesser price possibly but i have no clue about that. The v1 needs an adapter to work on M-mount cameras though. BTW the Heliar 15/4.5 v2 doesn't exhibit color shifts on M11 contrary to some ill-informed statements.
Edited by lct
I didn't know about this lens until this week...
That close focus is impressive! Ill have a look for one, thank you.
Yes, for a film M, it’s probably the ultimate solution. It shows no extra vignette with 39mm filters and even comes with a nice rectangular lens hood.
Edit - I would also add that it’s a good performer on the M11 with absolutely no color shift at the edges. It sounds like you are mainly thinking about use with film, so digital performance may not be pertinent.
Edited by J S H
You will be amazed just how small it is. Definitely the best bang for the buck on the M mount ultra wide front and undoubtedly the smallest full frame option. I was using mine for some interior architectural images yesterday and noticed that my normal 39mm polarizer created noticeable extra vignetting that was not a problem with thinner filters. I tested with a very thin polarizer and the vignetting is much better, but maybe still a little bit more obvious than with my thinner UV/IR filters. Not a dealbreaker though and easy enough to frame images with thicker filters a bit wider and crop, if necessary.
I use the V1 15mm f3.5 on my M8 and find it's excellent.
On my M-P 240 the red edges are an irritation and must be removed.  I've got very used to using Lightrooms Flat Field Correction which is easy to use and totally removes the red edges. I need it for 21mm  and 35mm lenses too.
I won't be buying another version 15mm as this one is OK.
This thread has quite the title!
If anyone is interested, click the photo below to go to a small album of landscape images made with the Laowa 15mm F/5.
Laowa 15mm F/5 on Flickr:
Edited by J S H
Fixed link
  • 3 months later...
