Noobi Posted December 12, 2024 Share #1 Posted December 12, 2024 Advertisement (gone after registration) Hello, looking to brainstorm about possible issues with the leica Q: "Camera powers on, but the lcd and viewfinder do not show the menu. The lcd backlight comes on". Any input would be appreciated! Thank you. Link to post Share on other sites More sharing options...
Advertisement Posted December 12, 2024 Posted December 12, 2024 Hi Noobi, Take a look here Q fails to boot. I'm sure you'll find what you were looking for!
jaapv Posted December 12, 2024 Share #2 Posted December 12, 2024 Normally the camera does not show a menu on startup but the image. Did you leave the lens cap on? Link to post Share on other sites More sharing options...
Noobi Posted December 12, 2024 Author Share #3 Posted December 12, 2024 Thank you for your reply. The lens cap is off, but the software does not display. Link to post Share on other sites More sharing options...
jaapv Posted December 12, 2024 Share #4 Posted December 12, 2024 What happens when you attempt to enter the menu screen? Otherwise remove the battery, wait a minute or so and reinsert. Link to post Share on other sites More sharing options...
Noobi Posted December 12, 2024 Author Share #5 Posted December 12, 2024 Camera has been tested with multiple batteries. The backlight on the lcd lights up, but images are not displaying. No menu, no image. Link to post Share on other sites More sharing options...
jgeenen Posted December 12, 2024 Share #6 Posted December 12, 2024 you tested different SD cards as well? Weirdest things can happen if the camera accesses a faulty SD card. Same behavior through EVF? If no, then it is likely the LCD screen or data transfer to it, if yes, then continue with next step. does the shutter release, do you hear the AF? No, then it could be everything up to a total electronic failure. If yes, do you get any images on an SD card? If no, electronic failure, if yes probably only the display electronics is failing. Link to post Share on other sites More sharing options...
jaapv Posted December 12, 2024 Share #7 Posted December 12, 2024 Advertisement (gone after registration) https://leica-camera.com/en-US/contact 1 Link to post Share on other sites More sharing options...
Noobi Posted December 13, 2024 Author Share #8 Posted December 13, 2024 12 hours ago, jgeenen said: you tested different SD cards as well? Weirdest things can happen if the camera accesses a faulty SD card. Same behavior through EVF? If no, then it is likely the LCD screen or data transfer to it, if yes, then continue with next step. does the shutter release, do you hear the AF? No, then it could be everything up to a total electronic failure. If yes, do you get any images on an SD card? If no, electronic failure, if yes probably only the display electronics is failing. Thank you so much for such a thorough response! A lot of good points for me to troubleshoot. You really helped me create an overarching test plan with a rough idea of possible issues. Link to post Share on other sites More sharing options...
