chrismuc Posted December 10, 2024 Share #1  Posted December 10, 2024 Advertisement (gone after registration) I searched but did not find any substantial information: Is the same 'thin' sensor glass used in the M11 and the SL3? Do wide angle rangefinder lenses from Leica, Zeiss, Voigtlander perform equivalent on a SL3 and a M11 regarding corner sharpness and (lack of) color cast or is the SL3 not as good? The SL3 performs better than the SL2 in that respect? Please share your experience. Thx. Link to post Share on other sites More sharing options...
Advertisement Posted December 10, 2024 Posted December 10, 2024 Hi chrismuc, Take a look here Leica SL3 vs. M11 with wide angle RF lenses. I'm sure you'll find what you were looking for!
Photoworks Posted December 10, 2024 Share #2 Â Posted December 10, 2024 yes yes no the look you get out of the M11 is different from SL3 Leica lenses with 6bit reads get in-camera correction, I can say exactly, but the results are cleaner on the SL3 than M11 Other brands or older lenses don't get any correction in camera. But you don't buy the M lenses for the clean look and performance, but for a look you get out of it. Link to post Share on other sites More sharing options...
jdlaing Posted December 10, 2024 Share #3 Â Posted December 10, 2024 Leica M cameras have offset microlenses to deal with wide angle lenses. The SL series do not. Link to post Share on other sites More sharing options...
Photoworks Posted December 10, 2024 Share #4 Â Posted December 10, 2024 33 minutes ago, jdlaing said: The SL series do not. where is this coming from? Microlenses have been on Sl2 and SL3, giving the same detailed images as on M camera from the center to the border. This is the main sensor difference between Leica and Panasonic. The benefit of this research to getting the same quality while using M lenses on an SL camera is beneficial for the adapted lenses from EF, and Nikon. Panasonic does not offer this as now, and the images on their camera do show softness and edge smearing with some wide angles. EF lenses perform better on the SL2 than any of the Sony mirrorless. as they improved micro-lenses tech, Leica was able to lenses away from the sensor in later models to reduce the dust spots. Link to post Share on other sites More sharing options...
Stuart Richardson Posted December 10, 2024 Share #5 Â Posted December 10, 2024 The order of image quality of wide angle M lenses from best to worst in my tests is: M Camera, SL Camera, a big drop in quality, then Panasonic, another drop in quality, Sony. Depending on how symmetrical the lens is and the degree of incidence of the light on the sensor, the difference between M and SL camera can be noticeable. For example, the 25mm biogon ZM is better on M bodies than the SL2. For most M lenses, the difference is not large, or even visible. But it is there for the lenses with the stronger angles of incidence. 1 Link to post Share on other sites More sharing options...
jdlaing Posted December 10, 2024 Share #6 Â Posted December 10, 2024 1 hour ago, Photoworks said: where is this coming from? Microlenses have been on Sl2 and SL3, giving the same detailed images as on M camera from the center to the border. This is the main sensor difference between Leica and Panasonic. The benefit of this research to getting the same quality while using M lenses on an SL camera is beneficial for the adapted lenses from EF, and Nikon. Panasonic does not offer this as now, and the images on their camera do show softness and edge smearing with some wide angles. EF lenses perform better on the SL2 than any of the Sony mirrorless. as they improved micro-lenses tech, Leica was able to lenses away from the sensor in later models to reduce the dust spots. All sensors have microlenses. The SL series do not have offset microlenses. Link to post Share on other sites More sharing options...
hdmesa Posted December 15, 2024 Share #7 Â Posted December 15, 2024 Advertisement (gone after registration) On 12/10/2024 at 12:21 PM, jdlaing said: ...The SL series do not have offset microlenses. Can you source this? I've read consistently over the years that the SL sensors have a microlens array that while not as aggressive as the M sensor, still have some favorability toward M lens ray angles compared to other mirrorless cameras. Link to post Share on other sites More sharing options...
